[SOLVED] Red light flashes next to barrel-port
#25
Here's another insight...
While building Manjaro's Linux kernel package, which pegs the CPU to 100% over a prolonged period of time and generates a lot of heat, I've noticed that the red LED next to the barrel plug starts flashing, and the battery starts to drain rapidly.  After a brief investigation, everything points into the direction of the battery charging IC (i.e., TI BQ24171) overheating as a result of increased internal temperature of the laptop.
Interestingly, if I turn the laptop upside-down, the red LED doesn't flash while bulding the kernel package.  Surely, this confirms that the root cause, in this case, is the BQ24171 IC overheating as a result of the heat generated by the SoC/CPU, in which case the BQ24171 IC stops charging the battery.
I'll try to affix a small heatsink to the BQ24171 IC, which might help a bit, and post the results back here.
RE: [SOLVED] Red light flashes next to barrel-port - by dsimic - 12-04-2020, 07:04 AM
  Blinking Tiny Blue Indicator Light? ArchiMark 3 1,199 06-30-2023, 03:15 PM
Last Post: Samurai_Crow
  How are people finding the type-A USB 3.0 port? chris88233 1 986 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Fried the charger port and USB leapylee 1 1,586 01-12-2022, 03:32 AM
Last Post: Danct12
  Serial port cable bsammon 17 24,433 03-04-2021, 10:00 AM
Last Post: mattpenn
  power light blinking during charge when pbpro is off Idaho 0 1,789 01-04-2021, 10:53 AM
Last Post: Idaho
  Boot issue (red light) pineitup 10 10,028 11-01-2020, 11:26 PM
  Orange light no boot blues :) feoh 6 7,393 10-13-2020, 11:11 AM
  Charging via USB-C Port tyha 15 20,027 07-22-2020, 08:15 PM
Last Post: iscmob
  Orange light won't boot>>>PineBook Pro user1gokou 4 6,355 07-10-2020, 03:04 PM
Exclamation [SOLVED] PBP will no longer power on s3rvant 10 10,223 07-04-2020, 01:57 PM
Last Post: prokofiev
