Google on Android?
(10-13-2020, 12:30 AM)KC9UDX Wrote: This might be a 7.x problem then.  I've tried and tried on several devices with this version, and nothing works.  Something in the system got updated in a way that's incompatible with the Play Store, I guess.
I do have a 9th generation (not sure what happened to 8th) Amazon fire tablet. It is based on Android 7. I could try to see if the same guides work for it also.
I happen to have an Android phone I bought in 2018 which happens to be version 7. It gets Google store updates all the time.
You may want to try one of those Guides to get Google play on Amazon fire tablets. There are numerous other services you have to install prior to actually putting the Google Play store on it.
I also have a Grandstream VoIP telephone which uses Android 4.2 or 4.4 as the interface in the screen. In this case, Google play store is not installed by default. They have their own Grandstream store installed. Though, there is a link in it to install Google Play store. It also works
Google on Android? - by KC9UDX - 07-05-2020, 01:11 PM
RE: Google on Android? - by TDC_PBP - 07-05-2020, 01:21 PM
RE: Google on Android? - by tophneal - 07-06-2020, 07:55 AM
RE: Google on Android? - by KC9UDX - 07-06-2020, 06:51 PM
RE: Google on Android? - by bastafari - 10-04-2020, 08:49 PM
RE: Google on Android? - by KC9UDX - 10-04-2020, 09:00 PM
RE: Google on Android? - by KNERD - 10-12-2020, 09:20 PM
RE: Google on Android? - by KC9UDX - 10-13-2020, 12:30 AM
RE: Google on Android? - by KNERD - 10-13-2020, 01:13 PM
RE: Google on Android? - by KC9UDX - 10-13-2020, 02:15 PM
Google on Android? - by bastafari - 10-13-2020, 07:32 PM
RE: Google on Android? - by Vinay - 11-15-2020, 03:21 PM
RE: Google on Android? - by KC9UDX - 11-15-2020, 03:42 PM
RE: Google on Android? - by Vinay - 11-16-2020, 01:04 AM
RE: Google on Android? - by Raniyah - 11-17-2020, 11:33 PM
RE: Google on Android? - by Vinay - 11-18-2020, 06:24 AM
RE: Google on Android? - by ab1jx - 01-23-2021, 08:30 PM
RE: Google on Android? - by kledo5 - 08-26-2021, 06:33 PM
RE: Google on Android? - by KNERD - 01-23-2021, 11:47 PM
RE: Google on Android? - by Djokovich - 03-15-2021, 03:21 AM
RE: Google on Android? - by Trenton Scales - 03-16-2023, 10:08 PM
RE: Google on Android? - by KC9UDX - 03-17-2023, 11:35 AM
  No Android build working! pin 60 115,997 07-03-2021, 06:08 PM
Last Post: justiceankomah
  MD5 On Android jaysistar 0 3,680 03-14-2020, 08:38 AM
Last Post: jaysistar
  Arguments for android support metcalsr 20 41,591 02-08-2020, 12:12 PM
Last Post: Idaho
Exclamation All android buillds on wiki for Microsd missing GPT? TDC_PBP 14 28,673 01-31-2020, 11:22 PM
  Any word about Android builds? tophneal 36 66,775 01-26-2020, 12:06 AM
Last Post: Account
  Flashing Updated U-Boot on Android tophneal 6 14,028 01-16-2020, 06:05 AM
