Ir codes for Android 9
A little bit more info about device:
getevent -lp /dev/input/event0
add device 1: /dev/input/event0
  events:
    KEY (0001): KEY_1                KEY_2                KEY_3                KEY_4
                KEY_5                KEY_6                KEY_7                KEY_8
                KEY_9                KEY_0                KEY_BACKSPACE        KEY_HOME
                KEY_UP                KEY_LEFT              KEY_RIGHT            KEY_DOWN
                KEY_DELETE            KEY_MUTE              KEY_VOLUMEDOWN        KEY_VOLUMEUP
                KEY_POWER            KEY_MENU              KEY_SETUP            KEY_WAKEUP
                KEY_BACK              KEY_PLAYPAUSE        KEY_F13              KEY_F14
                KEY_F15              KEY_F16              KEY_SEARCH            KEY_REPLY
                KEY_TEXT              KEY_BLUE              KEY_CHANNELUP
  input props:
    <none>
+ this:
rk3328_box:/ # getevent -i /dev/input/event0
  bus:      0019
  vendor    0001
  product   0001
  version   0100
  version:  1.0.1
  events:
    KEY (0001): 0002  0003  0004  0005  0006  0007  0008  0009
                000a  000b  000e  0066  0067  0069  006a  006c
                006f  0071  0072  0073  0074  008b  008d  008f
                009e  00a4  00b7  00b8  00b9  00ba  00d9  00e8
                0184  0191  0192
  input props:
    <none>
Somehow this codes should be mapped to this remote?
http://files.pine64.org/doc/Pine%20A64%2...t-logo.jpg
Ir codes for Android 9 - by Redwid - 07-05-2020, 06:35 AM
RE: Ir codes for Android 9 - by Redwid - 07-05-2020, 02:11 PM
RE: Ir codes for Android 9 - by Redwid - 07-07-2020, 04:37 AM
RE: Ir codes for Android 9 - by Redwid - 07-15-2020, 04:43 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,266 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,027 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,554 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,530 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,018 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,502 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,015 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,577 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,725 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,793 09-09-2020, 08:44 AM
Last Post: BowerR64
