NixOS getting started guide
(07-01-2020, 06:48 PM)_hg_ Wrote:
  1. Before building, make sure you are on the right channel with "nix-channel --list". I wanted 20.03 but was on unstable, so I had to run "nix-channel --add https://channels.nixos.org/nixos-20.03" followed by "nix-channel --update".
I don't think this step is needed, as the channel is specified in the nix expression here https://github.com/samueldr/wip-pinebook...ult.nix#L2.
It's also worth noting that you can use nixos-install to install the system to the SD or eMMC once on the PBP. I had good luck with this method in my setup. This also allows you a chance to create your own partition layout and tweak the /etc/nixos/configuration.nix for the first generation. For example, I use ZFS following the technique in https://grahamc.com/blog/erase-your-darlings on my PBP eMMC, with good results.
These steps look great! Perhaps these should be added to the repo?
NixOS getting started guide - by _hg_ - 07-01-2020, 06:48 PM
RE: NixOS getting started guide - by theotherjimmy - 07-02-2020, 09:52 AM
RE: NixOS getting started guide - by _hg_ - 07-03-2020, 07:27 AM
RE: NixOS getting started guide - by _hg_ - 07-06-2020, 08:02 PM
  My installation guide starting from messed up eMMC Besouro 0 3,012 12-19-2022, 01:01 PM
Last Post: Besouro
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 5,583 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
  General getting started James Good 10 19,712 12-13-2020, 01:17 PM
Last Post: James Good
  Manjaro 20.06 Step-By-Step Installation Guide nathanielwheeler 19 46,104 11-03-2020, 02:26 PM
Last Post: nathanielwheeler
