U-boot
u-boot doesn't have acess to the display on the PinePhone (only HDMI is support in u-boot), buttons should be supported however.
U-boot - by wasgurd - 06-26-2020, 08:36 PM
RE: U-boot - by a-wai - 06-27-2020, 02:48 AM
RE: U-boot - by wasgurd - 06-27-2020, 03:51 AM
RE: U-boot - by a-wai - 06-27-2020, 05:31 AM
RE: U-boot - by wibble - 06-27-2020, 07:44 AM
RE: U-boot - by a-wai - 06-27-2020, 09:17 AM
RE: U-boot - by wibble - 06-27-2020, 04:18 PM
  boot gets stuck shortly after disk decryption vortex 9 9,214 09-11-2024, 05:40 AM
Last Post: normangraves
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 7,632 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 3,483 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 1,808 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 2,243 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 3,581 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 2,201 03-06-2023, 12:06 PM
Last Post: freelectro
  [solved] Black screen at boot time mdk 0 2,035 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 2,311 01-04-2023, 06:46 PM
Last Post: 3x5co
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 5,385 12-31-2022, 10:56 AM
Last Post: DrPlamsa
