PBP lines across screen, halts whilst running (prev. will not power on)
Thank you for your replies. I have updated the title as it was now misleading as to the primary problem.
Earlier builds were not Manjaro. That is a more recent change.
SD card is fine, EMMC appears fine. Behaviour is the same irrespective of boot source.
I believe this is a hardware issue.
The machine will boot and run for a short while (from seconds to a few minutes). The display will then show various corrupt / garbage lines, and the machine will stop responding.
Possibly thermal-related; if it warms up the non-power on behaviour temporarily returns.
As the plastics are also breaking already despite minimal use, and as I’ve not got spare time for debugging the hardware, this will sadly be consigned to e-waste. Hopefully the other parts can be used for something else.
RE: PBP will not power on - by ajcollins - 06-25-2020, 07:06 AM
RE: PBP will not power on - by ajcollins - 06-25-2020, 09:30 AM
RE: PBP will not power on - by Alstroplane - 07-01-2020, 05:53 PM
RE: PBP will not power on - by xmixahlx - 07-02-2020, 09:46 AM
RE: PBP lines across screen, halts whilst running (prev. will not power on) - by ajcollins - 07-05-2020, 02:30 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 230 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,154 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,617 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,131 09-26-2022, 12:17 AM
Last Post: jonasd
  Malfunction: horizontal white streak on the screen regivanx 0 929 06-23-2022, 12:59 AM
Last Post: regivanx
  Troubleshooting of pinebook Pro red light and black screen wangyukunshan 0 1,686 03-23-2022, 12:10 AM
Last Post: wangyukunshan
  I broke my screen :( espenbo 3 2,901 01-03-2022, 03:46 PM
Last Post: altacus
  Blinking red light for charger, no power-on bifo 11 13,351 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,282 11-29-2021, 01:55 PM
Last Post: stozi
  Broken Screen vxzero 0 1,325 08-26-2021, 09:02 PM
Last Post: vxzero
