Screen won't shut off when fully closed
Most of the time, it shuts off.
Sometimes, it doesn't.  If I then lift the screen one or two inches, it shuts off again.  Then I can close it all the way, and it stays off.
But most of the time, it shuts off.  It usually takes a few seconds after I close it all the way.
I suspect there is some software switch that sometimes doesn't work.  Just like my bluetooth mouse sometimes doesn't work.  Usually I have to reboot, then delete the mouse from Bluetooth and add it again.
Things here are a bit finicky, not as stable as a machine that costs five or ten times as much, but I believe the hardware is fine, it's just a software something or other.
RE: Screen won't shut off when fully closed - by Phillip Bell - 06-25-2020, 10:30 PM
  Another one boots to black screen Sb2024 7 6,277 11-06-2024, 11:27 PM
Last Post: Sb2024
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 1,969 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 10,067 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 7,019 04-01-2023, 07:55 AM
Last Post: hacknix
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 5,707 10-08-2022, 06:22 PM
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 5,004 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 4,673 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 5,858 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 9,081 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  Screen refresh delay with kernel errors shawnanastasio 31 58,761 04-27-2021, 02:57 AM
Last Post: james64
