Manjaro 20.06 Step-By-Step Installation Guide
(06-25-2020, 01:30 AM)nathanielwheeler Wrote: I should have probably been more clear to that, when making the initial microSD card image, you should be on a system that uses an intel or amd chip, because Balena Etcher does not work on aarch64 (arm).  Etcher will therefore not work on PBP.
I've found that 'etcher-git' from the AUR Repos installs and works on the PBP. It took 2 attempts to install via the Manjaro default package manager Smile .
[Image: 2fae5e7ddac712b15872e347b19165b7-full.png]
Cheers!
RE: Manjaro 20.06 Step-By-Step Installation Guide - by MtnSk8 - 07-24-2020, 01:17 PM
  Fedora 37 installation gswatkins 16 5,513 03-16-2024, 03:09 PM
Last Post: michel_luc
  Manjaro Sway Theme Broken Eighty8 1 165 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,604 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 212 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,911 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,978 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 290 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 745 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,912 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,851 08-21-2023, 09:08 PM
