Manjaro 20.06 Step-By-Step Installation Guide
Hi Nathaniel
Many thanks for preparing this - the general absence of reliable documentation for this does make me pause and consider if I need to get rid of the PBP which is a shame.
I corrupted the default install when a corrupt component (breeze) turned up in the big July update. Not realising this was a key part of the GUI I removed the component and the factory linux gradually fell apart. I can see files on the eMMC drive but this version only gives a blank screen now.
Not a problem, I thought - just follow the guide you created as above and update to a new manjaro.
So:
obtain img file - check.
Verify hash - check.
obtain etcher on another computer and copy img to sd card - check.
After this all I get is a blank screen when trying to boot the PBP into either i3 or XFCE from the SD card.
It is as if the gui is displaying somewhere in the computer's memory, but not the screen, but of course I cannot tell.
The red light stays on for a while (presumably booting) and then goes green
The only light on the horizon is that the Arch Linux installer does appear to work but this is not an official build.
Any ideas how I can persuade either of these manjaro imgs to work from the SD card? Can I use a USB drive instead?
Best wishes and again thanks for putting the above out there which I have followed to the letter!
Alex
RE: Manjaro 20.06 Step-By-Step Installation Guide - by thepeckhambassplayer - 07-19-2020, 07:25 AM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,782 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,188 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,723 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,039 08-21-2024, 04:17 AM
  Fedora 37 installation gswatkins 16 16,134 03-16-2024, 03:09 PM
Last Post: michel_luc
  Manjaro Sway Theme Broken Eighty8 1 3,218 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,554 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,881 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,063 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,148 12-11-2023, 03:47 AM
Last Post: calinb
