[SOLVED] PBP will no longer power on
Exclamation
After receiving my PBP and tinkering with Manjaro (including fully updating the system) I decided I'd rather try out a more familiar distro so flashed @mrjay 's Ubuntu image; details here:
https://forum.pine64.org/showthread.php?...0#pid68220
The battery was showing 20% when flashing completed however once the system powered down it will no longer power up. The power button does not appear to have any effect at all.
I've tried searching the forums here for similar issues and so far have tried:
  • Booting with / without A/C adapter plugged in
  • Booting with / without SD card inserted
  • Verified that A/C adapter is charging (light comes on, charges then turns off)
  • Verified the A/C adapters are working by charging a 2nd PBP that is still working
  • Removed the battery, connected the power bypass cable and attempted to power on with A/C adapter
  • Reseated the eMMC
  • Booting with / without eMMC hardware switch toggled
Nothing appears to have had any effect and I'm not sure what else I can do; any advice would be much appreciated
[SOLVED] PBP will no longer power on - by s3rvant - 06-20-2020, 12:03 PM
RE: PBP will no longer power on - by TDC_PBP - 06-20-2020, 01:18 PM
RE: PBP will no longer power on - by Phillip Bell - 06-20-2020, 01:52 PM
RE: PBP will no longer power on - by s3rvant - 06-20-2020, 02:56 PM
RE: PBP will no longer power on - by s3rvant - 06-24-2020, 10:26 AM
RE: PBP will no longer power on - by brzegorz - 06-25-2020, 07:16 AM
RE: PBP will no longer power on - by s3rvant - 06-25-2020, 07:53 AM
RE: PBP will no longer power on - by s3rvant - 06-30-2020, 07:28 PM
  Pinebook64 Pro doesn't power on andrea_from_italy 9 5,499 03-20-2025, 10:07 AM
  Lockable-until-power-cycle persistent storage Melab 0 1,904 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 2,180 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 1,827 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 3,764 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 5,266 09-09-2022, 08:13 PM
  Pinebook pro no longer boots xsquared93 7 11,448 02-13-2021, 09:39 AM
  Replacement Power Cord recommendation? nathanielwheeler 3 5,469 01-23-2021, 06:43 PM
  [SOLVED] Red light flashes next to barrel-port Carl 31 62,322 01-18-2021, 09:34 AM
Last Post: dsimic
  power light blinking during charge when pbpro is off Idaho 0 3,464 01-04-2021, 10:53 AM
Last Post: Idaho
