openSUSE for Pinephone
#52
(01-02-2021, 04:20 AM)Alefnode Wrote:
(12-31-2020, 06:39 PM)andresbs Wrote: Already tested like 4-5 distros and openSUSE has given me the best experience so far, but I am left with a question and two issues:
-Is the 60 fps patch applied yet? It does not seem like (or it could be the PinePhone being what it is)
-I can't send SMS to anyone (Chatty), I keep getting that +5068888 is not a valid number (tried with spaces and no regional prefix, no success). I replicated this while installed on the eMMC and the SD card.
If I send an SMS to the PinePhone through another phone I can reply with no problems, the issue is with starting new conversations.
-When going to the devices section on Files or when opening whatever prompt that invokes files a constant mmblk notifications spams half of the screen (it's installed on the eMMC) and a ROOT partition constantly pops out and back in (or it seems like). I have no idea what this could be.
I think I may take a look at packaging some stuff for Plasma Mobile, priorities would be the Plasma Mobile config files, Neochat and basic IM apps (particularly Spacebar). I'm really new to OBS and so far only packaged one program, but I believe it is not that complicated once I get to know how to use some (definitely undocumented or underdocumented) macros. However, if this is going to happen, we should coordinate to avoid duplicating efforts.
I will check SMS, i dind't test that, maybe it's something from Chatty compilation.
I also created a Telegram Dev group to get all info together, it would be nice to work with you in Plasma version. Tell me via PM if you want the link to the new group.
Sorry about the delay, I was visiting a national park hehe
Packaging for Calindori, Spacebar and Angelfish are ready. I could not get adblock working on Angelfish due to missing (optional) deps, specifically Corrosion/cmake-cargo.
Dudes from Plasma Mobile advised to keep an eye on ofono (it's used instead of modemmanager), which is good news because that's what UB Touch also uses, so it's a 2x1 Smile
***RPMs might have missing deps, please someone test on a fresh openSUSE image. Example: install using "opi calindori".
Angelfish feels soooooo much smoother than Epiphany, I just couldn't handle it, so sluggish.
openSUSE for Pinephone - by Alefnode - 06-19-2020, 02:02 AM
RE: openSUSE en Pinephone - by Alefnode - 06-20-2020, 08:44 AM
RE: openSUSE en Pinephone - by pizzalovingnerd - 06-20-2020, 06:08 PM
RE: openSUSE en Pinephone - by Alefnode - 06-21-2020, 06:59 AM
RE: openSUSE en Pinephone - by Alefnode - 06-22-2020, 07:20 AM
RE: openSUSE en Pinephone - by hackersgame - 06-24-2020, 06:00 PM
RE: openSUSE en Pinephone - by Alefnode - 06-25-2020, 04:15 AM
RE: openSUSE en Pinephone - by Alefnode - 06-27-2020, 04:24 AM
RE: openSUSE en Pinephone - by Kamzzy - 06-27-2020, 01:00 PM
RE: openSUSE en Pinephone - by Alefnode - 06-29-2020, 02:28 AM
RE: openSUSE en Pinephone - by Kamzzy - 06-29-2020, 11:35 AM
RE: openSUSE en Pinephone - by Alefnode - 06-30-2020, 04:56 AM
RE: openSUSE en Pinephone - by hackersgame - 06-30-2020, 08:39 AM
RE: openSUSE en Pinephone - by Alefnode - 07-02-2020, 05:04 AM
RE: openSUSE en Pinephone - by Alefnode - 07-02-2020, 01:54 PM
RE: openSUSE en Pinephone - by Jojonintendo - 07-04-2020, 02:25 AM
RE: openSUSE en Pinephone - by wibble - 07-05-2020, 10:38 AM
RE: openSUSE en Pinephone - by Alefnode - 07-23-2020, 07:25 AM
RE: openSUSE en Pinephone - by Alefnode - 07-06-2020, 04:32 AM
RE: openSUSE en Pinephone - by Jojonintendo - 07-12-2020, 05:37 AM
RE: openSUSE en Pinephone - by Hyz - 07-28-2020, 06:18 PM
RE: openSUSE en Pinephone - by Alefnode - 07-30-2020, 01:50 AM
RE: openSUSE en Pinephone - by Alefnode - 07-29-2020, 12:46 AM
RE: openSUSE for Pinephone - by Hyz - 08-06-2020, 10:24 PM
RE: openSUSE for Pinephone - by Alefnode - 08-31-2020, 07:45 AM
RE: openSUSE for Pinephone - by Alefnode - 09-18-2020, 02:17 AM
RE: openSUSE for Pinephone - by ccgx - 09-19-2020, 11:17 AM
RE: openSUSE for Pinephone - by Alefnode - 09-25-2020, 03:04 AM
RE: openSUSE for Pinephone - by Alefnode - 10-14-2020, 07:41 AM
RE: openSUSE for Pinephone - by georgep56 - 10-15-2020, 12:26 PM
RE: openSUSE for Pinephone - by Alefnode - 10-30-2020, 03:06 AM
RE: openSUSE for Pinephone - by andresbs - 11-04-2020, 01:39 PM
RE: openSUSE for Pinephone - by Alefnode - 11-10-2020, 05:01 AM
RE: openSUSE for Pinephone - by andresbs - 12-20-2020, 08:26 AM
RE: openSUSE for Pinephone - by Alefnode - 11-17-2020, 01:45 AM
RE: openSUSE for Pinephone - by LinAdmin2 - 11-17-2020, 11:18 AM
RE: openSUSE for Pinephone - by LinAdmin2 - 11-19-2020, 03:59 AM
RE: openSUSE for Pinephone - by Chrono - 11-18-2020, 01:16 PM
RE: openSUSE for Pinephone - by Xray2000 - 11-18-2020, 02:54 PM
RE: openSUSE for Pinephone - by LinAdmin2 - 11-20-2020, 03:00 AM
RE: openSUSE for Pinephone - by plainenough - 11-20-2020, 09:20 AM
RE: openSUSE for Pinephone - by LinAdmin2 - 11-20-2020, 02:30 PM
RE: openSUSE for Pinephone - by plainenough - 11-23-2020, 10:25 AM
RE: openSUSE for Pinephone - by choozy - 11-25-2020, 04:54 PM
RE: openSUSE for Pinephone - by Alefnode - 12-16-2020, 03:53 PM
RE: openSUSE for Pinephone - by Xray2000 - 11-27-2020, 05:09 AM
RE: openSUSE for Pinephone - by darkdragon-001 - 11-28-2020, 04:16 PM
RE: openSUSE for Pinephone - by andresbs - 12-19-2020, 08:33 AM
RE: openSUSE for Pinephone - by Alefnode - 12-22-2020, 06:41 AM
RE: openSUSE for Pinephone - by andresbs - 12-31-2020, 06:39 PM
RE: openSUSE for Pinephone - by Alefnode - 01-02-2021, 04:20 AM
RE: openSUSE for Pinephone - by andresbs - 01-02-2021, 09:17 PM
RE: openSUSE for Pinephone - by andresbs - 01-13-2021, 08:59 PM
RE: openSUSE for Pinephone - by Alefnode - 02-03-2021, 09:43 AM
RE: openSUSE for Pinephone - by gergob - 02-03-2021, 01:55 PM
RE: openSUSE for Pinephone - by andresbs - 02-03-2021, 11:45 PM
RE: openSUSE for Pinephone - by Juergen - 02-21-2021, 08:43 AM
RE: openSUSE for Pinephone - by andresbs - 02-21-2021, 08:54 AM
RE: openSUSE for Pinephone - by Uturn - 03-03-2021, 06:56 AM
RE: openSUSE for Pinephone - by andresbs - 03-03-2021, 07:54 AM
RE: openSUSE for Pinephone - by Uturn - 03-03-2021, 09:48 AM
RE: openSUSE for Pinephone Accounts - by Uturn - 03-04-2021, 03:38 AM
RE: openSUSE for Pinephone Accounts - by andresbs - 03-05-2021, 10:14 AM
RE: openSUSE for Pinephone Accounts - by Uturn - 03-05-2021, 10:45 AM
RE: openSUSE for Pinephone Accounts - by andresbs - 03-05-2021, 11:13 AM
RE: openSUSE for Pinephone - by JimSmith80 - 03-18-2021, 09:09 PM
RE: openSUSE for Pinephone - by andresbs - 03-18-2021, 09:18 PM
RE: openSUSE for Pinephone - by Uturn - 03-21-2021, 06:02 AM
RE: openSUSE for Pinephone - by andresbs - 03-21-2021, 11:43 AM
RE: openSUSE for Pinephone - by flembcke - 11-27-2021, 08:31 AM
RE: openSUSE for Pinephone - by ragreenburg - 12-02-2021, 10:36 AM
RE: openSUSE for Pinephone - by flembcke - 05-15-2022, 10:44 AM
RE: openSUSE for Pinephone - by Uturn - 11-20-2022, 11:28 AM
RE: openSUSE for Pinephone - by Eugo - 11-26-2022, 12:07 PM
RE: openSUSE for Pinephone - by Uturn - 11-15-2023, 02:31 AM
RE: openSUSE for Pinephone - by Uturn - 11-17-2023, 08:37 AM
  Movuan distribution for PinePhone merom 5 4,688 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,040 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Latest firmware for PinePhone modem! Subsentient 105 199,648 02-02-2025, 08:47 PM
Last Post: bacydentir85
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 54,067 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,305 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 58,521 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 5,604 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 14,890 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 3,790 06-16-2024, 10:26 PM
  Possible Free Backup Carrier for PinePhone PineFone 0 3,683 06-13-2024, 03:45 PM
Last Post: PineFone
