USB hub as to connect some extra device
(05-13-2016, 04:30 AM)Ghanshyam Wrote: Hi
 I would like to connect my usb keyboard and mouse to my pine 2gb using usb hub I am currently using Remix OS 2.0 .
When i connect directly the usb keyboard and mouse to pine it works absolutely fine.
But problem as pine have only two usb port when i have connected  usb keyboard and mouse i would also like to connect my external hdd and usb pendrive.
so i tried to use 4 port usb hub but it was not able detect or not working the usb keyborad and mouse
I like to knew its this problem with Remix OS or o/p usb power is not sufficient to use hub.  Huh Huh
I am not certain but the USB2 port delivers 500ma of power, so if you want to attach an external USB2 drive then you should use a powered hub instead. Especially since you have other devices connected.
RE: USB hub as to connect some extra device - by Luke - 05-13-2016, 04:45 AM
