Battery draining with external power while under load?
(06-24-2020, 05:24 PM)Upokupo Wrote: Thank you for the reply and reasserting my perspective. I forgot what I was getting myself into.  Aside from rough edges this thing is amazing! I plan on giving my initial impressions in the proper thread. Sorry it took a while to respond. Been dealing with a lot of health issues with family members. I will be making the change to have it run directly off of the barrel plug and unplugging the battery when I get some downtime to tinker some more. I WILL make this my daily driver come hell or high water. Big Grin
Sure - and that's the right perspective to have, IMO. The hardware is good enough to use extensively, but it's far from perfect, and the software support is still a bit rough around the edges. Random kernel issues, hardware support that's good-but-not-great (see uboot - you can run mainline, at the cost of deep sleep - and if you run the BSP one with deep sleep, you lose sound some of the time on resume), etc.
"I'll daily driver it come hell or high water," and then reporting/fixing the issues, is exactly what the platform needs right now. Grumbling about the quirks, as was being done upthread, isn't terribly productive. Note them, report them, see if you can work around them, but it's a $200 laptop being sold basically at cost, to shake out the weird stuff.
RE: Battery draining with external power while under load? - by Syonyk - 06-24-2020, 08:33 PM
  Lockable-until-power-cycle persistent storage Melab 0 667 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 789 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 577 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,138 02-25-2023, 09:00 PM
Last Post: badguru
  Pinebook Pro drains ny battery after shutting it off Tongman 4 2,022 12-01-2022, 02:50 AM
  Battery Frost1776 1 996 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 2,421 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 2,162 09-09-2022, 08:13 PM
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,360 02-22-2022, 11:20 AM
  high battery drain on suspend/poweroff wiz 5 4,919 02-10-2022, 11:52 AM
