How to set up auto logon?
(06-04-2016, 06:48 PM)coolnine98 Wrote:
(06-04-2016, 06:27 PM)Luke Wrote:
(06-04-2016, 05:14 PM)coolnine98 Wrote:
(05-12-2016, 05:15 PM)Luke Wrote: In terminal, try navigating to  /usr/share/lightdm/lightdm.conf.d/
Use nano to edit the config and add this line: autologin-user=[username]
Close and save.
See if this does the trick Smile
It did not work. As per your instruction I added a line to "sudo nano /usr/share/lightdm/lightdm.conf.d/01_debian.conf", but still my "dont ask logon password" check box still grayed out.
What should I do now?
Instead of [username] use the actual user. So for instance, for Debian that would be: autologin-user=debian
Thanks. I already did that. see below.
[SeatDefaults]
greeter-session=lightdm-greeter
greeter-hide-users=true
session-wrapper=/etc/X11/Xsession
autologin-user=[pine64user]
I have kept it same login. I also tried with changing to new name as "coolnine98" name but still no luck so I revert back to default username=pine64user.
Remove the brackets around "pine64user" and that will (I hope) solve it. The brackets were supposed to call attention to the fact that what's inside them is a placeholder, not the actual wording.
Oh, and that checkbox will still be greyed out. It is on mine too. But that's not a problem because the system boots up fully without asking for a password once you've got that added line configured right.
How to set up auto logon? - by thehamguy1 - 05-12-2016, 03:55 PM
RE: How to set up auto logon? - by thehamguy1 - 05-12-2016, 05:06 PM
RE: How to set up auto logon? - by Luke - 05-12-2016, 05:15 PM
RE: How to set up auto logon? - by pelgrim - 05-21-2016, 06:50 AM
RE: How to set up auto logon? - by thehamguy1 - 05-21-2016, 07:11 AM
RE: How to set up auto logon? - by coolnine98 - 06-04-2016, 05:14 PM
RE: How to set up auto logon? - by Luke - 06-04-2016, 06:27 PM
RE: How to set up auto logon? - by coolnine98 - 06-04-2016, 06:48 PM
RE: How to set up auto logon? - by thehamguy1 - 06-04-2016, 07:06 PM
RE: How to set up auto logon? - by Luke - 06-04-2016, 07:18 PM
RE: How to set up auto logon? - by coolnine98 - 06-05-2016, 03:31 PM
RE: How to set up auto logon? - by thehamguy1 - 05-12-2016, 07:41 PM
RE: How to set up auto logon? - by Luke - 05-13-2016, 05:29 AM
RE: How to set up auto logon? - by pelgrim - 05-21-2016, 08:03 AM
RE: How to set up auto logon? - by thehamguy1 - 05-21-2016, 08:27 AM
RE: How to set up auto logon? - by pelgrim - 05-21-2016, 08:45 AM
RE: How to set up auto logon? - by thehamguy1 - 06-07-2016, 04:29 PM
