Silly question: What is the new ANX demo image?
(06-19-2020, 08:20 AM)MartijnBraam Wrote: yeah I've noticed this issue, I'm looking into a fix. the current brightness is set in the kernel dtb so not easy to manually change. main issue is that autobrightness is behaving very broken.
Yea, it definitely seemed a little all over the place, but I figured it would get fixed after a little bit anyway.
I just want to get the manual brightness slider under control so that the user experience for people getting the PmOS version of PP don't accidentally black their screens with no clue how to fix it. However, I'm also hoping that you dont go as conservative as mobian and a few others seem to. I like my screen DARK, and I dont know where the voltage cut off is, but I like that I can get my screen very low with the current bar, I just have to be careful not to go too far...
Hopefully I can keep learning enough to be able to just submit some code for you all at some point, but I'm still pretty new to coding for hardware.
RE: Silly question: What is the new ANX demo image? - by gotomech - 06-19-2020, 10:07 AM
  Security/Musl Question publiclewdness 1 2,113 08-21-2021, 12:38 AM
Last Post: moonwalkers
  Where is the original PM OS image for Pinephone? mw4jet 1 2,621 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,704 02-28-2021, 02:20 PM
Last Post: MtnSk8
  Cricket Wireless HD voice question Hobbes42 3 4,161 02-01-2021, 03:53 AM
Last Post: rocket2nfinity
  Is a Software update the same as instaling an updated image Word5 1 2,932 09-19-2020, 10:23 PM
Last Post: jmorris
  Incorrect Passphrase - FIx | How To Reinstall Image. NobodyNew1 0 2,133 09-02-2020, 09:30 PM
Last Post: NobodyNew1
  sxmo image Verizon calls and SMS work! Saliency 8 8,687 08-22-2020, 03:28 AM
Last Post: PureTryOut
  PostmarketOS is my favorite so far. Question about USB Switch mod of UBPorts Edition. pcdoodle 2 3,613 08-19-2020, 02:24 PM
Last Post: natasha
  Latest Installer Image hangs after updates u20200719 4 5,655 07-22-2020, 11:35 AM
Last Post: u20200719
  Dumb question: do I have to use pmbootstrap? quixote 5 6,966 06-11-2020, 09:23 AM
Last Post: plainenough
