On/Off Switch Pad Working Bad
#20
(06-28-2016, 01:11 PM)DonFL Wrote: I've had "as expected" behavior, running an android image, or a debian image, either shorting the pads (before I got switches) or after. Power on, and power off. Obviously, linux behavior and response is not the same as android.
There is no reason I can see that the switch has to be installed to work as opposed to just putting a jumper across the pads. There's nothing magical being done here that suggest a mechanical switch is required.
Can you provide a picture or diagram of how I would jumper the power pads without a switch?  Thanks.  Rick
On/Off Switch Pad Working Bad - by RaspiBit - 05-12-2016, 12:51 PM
RE: On/Off Switch Pad Working Bad - by Ghost - 05-12-2016, 04:22 PM
RE: On/Off Switch Pad Working Bad - by RaspiBit - 05-13-2016, 04:19 PM
RE: On/Off Switch Pad Working Bad - by rodenti - 06-22-2016, 10:08 PM
RE: On/Off Switch Pad Working Bad - by Xabaras76 - 06-22-2016, 10:34 PM
RE: On/Off Switch Pad Working Bad - by Xabaras76 - 06-23-2016, 11:55 AM
RE: On/Off Switch Pad Working Bad - by Xabaras76 - 06-23-2016, 02:35 PM
RE: On/Off Switch Pad Working Bad - by xalius - 06-23-2016, 03:26 PM
RE: On/Off Switch Pad Working Bad - by Xabaras76 - 06-23-2016, 05:32 PM
RE: On/Off Switch Pad Working Bad - by Xabaras76 - 06-27-2016, 10:24 AM
RE: On/Off Switch Pad Working Bad - by pfeerick - 06-28-2016, 02:28 AM
RE: On/Off Switch Pad Working Bad - by pfeerick - 06-28-2016, 09:20 PM
RE: On/Off Switch Pad Working Bad - by DonFL - 06-28-2016, 01:11 PM
RE: On/Off Switch Pad Working Bad - by rvalecruz - 06-29-2016, 03:14 PM
RE: On/Off Switch Pad Working Bad - by DonFL - 06-29-2016, 03:45 PM
  Working linux distribution that supports BT/Wifi on A64 Roverius 3 4,822 08-19-2019, 04:47 AM
Last Post: Roverius
  assistantpine, a working idea for a distro tohipfortheroom 1 3,383 01-22-2017, 02:56 AM
  Support registration seems not to be working winterflaw 2 3,702 11-04-2016, 02:08 PM
Last Post: winterflaw
  UAE4Droid Amiga emulator not working Middleman 1 3,130 07-25-2016, 04:18 AM
Last Post: CaptainZalo
  Bluetooth not working reesh95 0 1,657 04-28-2016, 01:29 AM
Last Post: reesh95
