06-11-2020, 08:56 PM
I am trying to get a Lenovo ThinkVision USB C monitor working with my pinebook pro running debian w/the manjaro 5.7 kernel.
when I plug in the monitor dmesg produces
A diff of lsusb reveals
Is there any particular firmware/module that I'm missing? I haven't been able to find anything.
Thanks in advance!
[ 760.964053] usb 7-1: USB disconnect, device number 32
[ 760.964163] usb 7-1.3: USB disconnect, device number 33
[ 760.967215] usb 7-1.4: USB disconnect, device number 34
[ 760.973941] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[ 760.980924] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[ 765.823271] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[ 766.150886] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[ 766.218518] typec_displayport port0-partner.0: No compatible pin configuration found:0000 -> 000c, 001c <- 0000
[ 767.151965] usb 7-1: new high-speed USB device number 35 using xhci-hcd
[ 767.345096] usb 7-1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.23
[ 767.345106] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 767.345111] usb 7-1: Product: 4-Port USB 2.0 Hub
[ 767.345115] usb 7-1: Manufacturer: Generic
[ 767.408343] hub 7-1:1.0: USB hub found
[ 767.409572] hub 7-1:1.0: 4 ports detected
[ 767.791792] usb 7-1.3: new full-speed USB device number 36 using xhci-hcd
[ 767.931623] usb 7-1.3: not running at top speed; connect to a high speed hub
[ 767.940423] usb 7-1.3: New USB device found, idVendor=17ef, idProduct=a361, bcdDevice= 3.00
[ 767.940447] usb 7-1.3: New USB device strings: Mfr=17, Product=18, SerialNumber=19
[ 767.940464] usb 7-1.3: Product: BillBoard Device
[ 767.940478] usb 7-1.3: Manufacturer: Realtek
[ 767.940493] usb 7-1.3: SerialNumber: 123456789ABCDEFGH
[ 768.251772] usb 7-1.4: new high-speed USB device number 37 using xhci-hcd
[ 768.395625] usb 7-1.4: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.23
[ 768.395649] usb 7-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 768.395665] usb 7-1.4: Product: 4-Port USB 2.0 Hub
[ 768.395680] usb 7-1.4: Manufacturer: Generic
[ 768.432313] hub 7-1.4:1.0: USB hub found
[ 768.433595] hub 7-1.4:1.0: 2 ports detected
Bus 007 Device 028: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 007 Device 027: ID 17ef:a361 Lenovo
Bus 007 Device 026: ID 0bda:5411 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Thanks in advance!
