Can't boot up Manjaro 20.04 eMMc image from SD card...
#20
(06-23-2020, 12:35 PM)rick1959 Wrote:
(06-23-2020, 12:31 PM)nathanielwheeler Wrote:
(06-23-2020, 08:08 AM)carlosqueso Wrote:
(06-23-2020, 06:35 AM)rick1959 Wrote: I've been able to install either Manjaro XFCE or KDE....However, when it comes to running the first update, I get an error message saying that "usr/lib/P11-kit.trust" already exists and then terminates the update.
Being that it occurs regardless of which image, KDE or XCFE, I use (both were checksummed) I get the same issue.
So, it seems there's something going on. Wonder if my PBP has an internal problem....
So I think this is an issue with Arch.  I had to run:
pamac update --overwrite /usr/lib\*/p11-kit-trust.so
to get the updates to install.
Got the idea from here: https://www.archlinux.org/news/nss3511-1...ervention/
but changed it to use pamac instead of the upstream Arch.
How do I access wifi from the microSD?  iwconfig and netctl aren't installed, so I'm not sure how I can update this library.
You're using the NON-eMMC file (image), right? On the SD card...?
Yes, currently logged in as root@manjaro-arm, which is the microSD card.  I suppose I could log into the eMMC as debian, but I don't know how I would make changes from there to the microSD image.
RE: Can't boot up Manjaro 20.04 eMMc image from SD card... - by nathanielwheeler - 06-23-2020, 12:37 PM
  Fix for Armbian not booting on PBP from eMMC agreenbhm 6 1,592 03-25-2023, 11:39 AM
Last Post: diederik
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 5 151 03-21-2023, 11:21 PM
Last Post: calinb
  Manjaro update: nerd-font-terminus dependency issue Vinay 2 151 03-01-2023, 11:18 AM
Last Post: Vinay
  Manjaro update broke hardware video acceleration with mpv myself600 2 418 01-25-2023, 09:12 AM
Last Post: myself600
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 0 186 01-19-2023, 01:47 PM
Last Post: Cs137
  Manjaro ARM 20.04 spikerguy 68 81,373 01-08-2023, 07:22 PM
Last Post: vandys
  org.kde.plasma.core not installed (Manjaro) twirlip 0 203 01-06-2023, 09:47 AM
Last Post: twirlip
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 2 499 12-31-2022, 12:18 PM
Last Post: pine4546464
  My installation guide starting from messed up eMMC Besouro 0 364 12-19-2022, 01:01 PM
Last Post: Besouro
  Tow Boot install help Paulie420 7 1,563 11-24-2022, 10:24 AM
