Can't boot up Manjaro 20.04 eMMc image from SD card...
(06-23-2020, 08:08 AM)carlosqueso Wrote:
(06-23-2020, 06:35 AM)rick1959 Wrote: I've been able to install either Manjaro XFCE or KDE....However, when it comes to running the first update, I get an error message saying that "usr/lib/P11-kit.trust" already exists and then terminates the update.
Being that it occurs regardless of which image, KDE or XCFE, I use (both were checksummed) I get the same issue.
So, it seems there's something going on. Wonder if my PBP has an internal problem....
So I think this is an issue with Arch.  I had to run:
pamac update --overwrite /usr/lib\*/p11-kit-trust.so
to get the updates to install.
Got the idea from here: https://www.archlinux.org/news/nss3511-1...ervention/
but changed it to use pamac instead of the upstream Arch.
How do I access wifi from the microSD?  iwconfig and netctl aren't installed, so I'm not sure how I can update this library.
RE: Can't boot up Manjaro 20.04 eMMc image from SD card... - by nathanielwheeler - 06-23-2020, 12:31 PM
  Manjaro Sway Theme Broken Eighty8 1 278 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,547 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,746 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 326 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,128 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,196 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 402 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,222 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 884 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,017 08-21-2023, 09:10 PM
Last Post: vanessadonald
