Can't boot up Manjaro 20.04 eMMc image from SD card...
(06-23-2020, 08:08 AM)carlosqueso Wrote:
(06-23-2020, 06:35 AM)rick1959 Wrote: I've been able to install either Manjaro XFCE or KDE....However, when it comes to running the first update, I get an error message saying that "usr/lib/P11-kit.trust" already exists and then terminates the update.
Being that it occurs regardless of which image, KDE or XCFE, I use (both were checksummed) I get the same issue.
So, it seems there's something going on. Wonder if my PBP has an internal problem....
So I think this is an issue with Arch.  I had to run:
pamac update --overwrite /usr/lib\*/p11-kit-trust.so
to get the updates to install.
Got the idea from here: https://www.archlinux.org/news/nss3511-1...ervention/
but changed it to use pamac instead of the upstream Arch.
Ahhh, Thank You!!
I'll give it a try now...:-)
Thank You!!
It worked perfectly. Went from ready to give up to happy camper! Perhaps you might want to add that to the wiki?
Seems too valuable to not put in the wiki...Have you thought about it??
Hope you do...:-)
P.S. I'm skilled at passing the buck! :-)
RE: Can't boot up Manjaro 20.04 eMMc image from SD card... - by User 6582 - 06-23-2020, 11:41 AM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,893 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  What's a good image to use now? [tutorial help as well] frank_philip 40 21,894 07-18-2025, 07:28 PM
  Boot Order in Pinebook Pro food 11 12,022 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,342 03-15-2025, 01:47 AM
Last Post: frank_philip
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 11,909 03-10-2025, 01:55 PM
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,887 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,196 08-21-2024, 04:17 AM
  Manjaro Sway Theme Broken Eighty8 1 3,296 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 12,909 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,696 02-02-2024, 02:45 AM
Last Post: frankkinney
