Can't boot up Manjaro 20.04 eMMc image from SD card...
(06-10-2020, 09:12 PM)Samurai_Crow Wrote: Try hitting any key at the splash screen.  Maybe it will advance.
Thanks for the suggestion, but it doesn't seem to work. Very odd.
I'm sure there must be something I'm missing..
This is one of the first hundred  PBP. Wondering if there's something different about this one that is causing an issue?
RE: Can't boot up Manjaro 20.04 eMMc image from SD card... - by User 6582 - 06-11-2020, 06:59 AM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,937 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  What's a good image to use now? [tutorial help as well] frank_philip 40 22,394 07-18-2025, 07:28 PM
  Boot Order in Pinebook Pro food 11 12,185 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,421 03-15-2025, 01:47 AM
Last Post: frank_philip
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 12,243 03-10-2025, 01:55 PM
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,991 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,284 08-21-2024, 04:17 AM
  Manjaro Sway Theme Broken Eighty8 1 3,323 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 13,075 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,744 02-02-2024, 02:45 AM
Last Post: frankkinney
