wifi does not work - authentication problem?
(06-11-2020, 03:06 AM)nobodyinperson Wrote:
(06-09-2020, 10:17 PM)Saliency Wrote: I have definitely experienced what looked like an Auth problem, where my WiFi password wasn’t accepted. Like during initial setup. But a warm reboot (power button -> restart ; NOT shut down) seems to solve it.
Indeed, that seems to solve it. I had the same problem and then „it somehow worked at some point”, guess I rebooted. Thanks for finding this out!
In my case it was a little bit more complicated. Obviously the NetworkManager caused the issue.
Fortunately I have an M10 with Ubports and working WiFi.
Today I compared the respective wireless setup file under /etc/NetworkManager/system-connections and found out that some items are missing or corrupt (i.e. the passphrase). To get it up and running I just copied this file, edited the UUID and the MAC-Address and added the missing information. A reboot enabled authentication, but the dhcp client did not get an IP-address at first. After powering off and powering on again I got an IP-address.
WIFI is now working Big Grin - Hopefully this remains stable Smile
Important updates are installed. Now I can *really* play around with this amazing device
Thanks and best
Mat
RE: wifi does not work - authentication problem? - by pphone-newbie - 06-23-2020, 06:58 AM
  Is there any way to tell CRUST to leave the wifi alone? Athansor 5 7,702 09-25-2020, 04:46 AM
Last Post: wibble
  Boot source problem. Issue confirmed. Thread renamed. Cree 2 3,782 08-26-2020, 12:47 PM
Last Post: Cree
  Any chance that we get WiFi texting/calling on UT? ragreenburg 0 2,106 08-04-2020, 09:13 AM
Last Post: ragreenburg
  Sound won’t work LMalilil 2 3,960 07-28-2020, 09:52 AM
Last Post: Cree
  dropdown menu doesn't work daniel 3 4,738 07-22-2020, 01:17 PM
Last Post: natasha
  Cellular switch (sw1) causes wifi to stop working blihp 4 6,091 07-21-2020, 10:30 PM
Last Post: blihp
  5Ghz Wifi Question LMalilil 3 5,774 07-10-2020, 03:09 PM
Last Post: hiimtye
  Does Miracast work? mercrapper 1 3,103 06-25-2020, 08:18 AM
Last Post: heng
  Only the top few rows of pixels work on stable OTA 3 NoraCodes 0 1,994 06-18-2020, 09:18 AM
Last Post: NoraCodes
  Ubports OTA won't work on my braveheart none 12 14,834 06-13-2020, 03:23 AM
Last Post: tsar_chasm
