180 degree screen tilt mod - works for me!
Thumbs Up
One thing missing from the PBP as shipped is a 180 degree screen tilt rotation. This is a great feature of Thinkpads that I immediately felt was lacking upon receiving my PBP.
Well I've recently made an unintentional but wonderful discovery. If you push the screen to the maximum point and apply some force, you can break the hinge that makes it stop at 120 degrees or whatever the original max tilt is. But it seems like the way the hinge breaks (or atleast the way the hinge broke on my PBP.. early January model), doesn't make it unstable and basically bending the PBP screen past it's normal max tilt just, unlocked if you will, 180 degree full tilt.
This was a completely unintentional discovery and I thought initially when I was pushing back on it and heard the snap, my PBP would now be useless; but to my surprise, I heard a snap, and now well my PBP has a great full 180 degree tilt. After I bent the screen back and heard the snap, I heard some loose inside the PBP - taking off the bottom cover I found two small metal bits from each of the hinge.
For me after doing this, there's no real wobble or instability as far as I can tell and the hing seems sturdy for the full 180 degrees - so I think what broke off (those metal bits are just stoppers that prevent tilting past the original tilt).
Try this at your own risk ofcourse, but for me this makes the PBP an even better Shy
 [Image: pbptilt.png]
180 degree screen tilt mod - works for me! - by mil - 06-07-2020, 09:28 PM
  Malfunction: horizontal white streak on the screen regivanx 0 970 06-23-2022, 12:59 AM
Last Post: regivanx
  Troubleshooting of pinebook Pro red light and black screen wangyukunshan 0 1,735 03-23-2022, 12:10 AM
Last Post: wangyukunshan
  I broke my screen :( espenbo 3 3,004 01-03-2022, 03:46 PM
Last Post: altacus
  Broken Screen vxzero 0 1,365 08-26-2021, 09:02 PM
Last Post: vxzero
Lightbulb Bluetooth headsets - what works? embhorn 17 23,941 03-22-2021, 11:45 PM
Last Post: ab1jx
  Screen offset nobodyinperson 7 9,062 01-26-2021, 04:55 PM
  Pinebook Pro screen failure? BBreeziN 1 2,949 01-08-2021, 03:21 PM
Last Post: member
  Defective screen? ryn1x 4 5,830 11-16-2020, 06:44 PM
Last Post: Lyrixcaz
  Horrible screen flicker/strobe on battery power mattjb 19 24,778 09-14-2020, 03:19 AM
Last Post: m.bakhterev
  PBP not booting screen blank after SD card boot Jakobp 10 13,705 08-18-2020, 08:56 PM
Last Post: trinapicot
