Samba Server
(05-11-2016, 11:55 AM)tkaiser Wrote:
(05-11-2016, 10:28 AM)rahlquist Wrote: I dont believe the Pine64 or virtually any SBC is a good viable NAS device.
It depends. For some special use cases A20 based devices (A20 has a real SATA implementation) are great. Last year rumours were spread that we'll see a quad core A20 successor this year. Interestingly in A64 BSP (both 1.2 and 2.0) nove, a linux-sunxi dev, found references for a not yet available A20E (dual core ARMv7 with higher CPU and DRAM clockspeeds but still pin compatible)
If A20E would show higher sequential SATA write speeds it gets interesting again.
We use A20 and H3 devices at customers in a 'dual role'. They do their normal job (eg. authenticated scan/print server doing also some GPIO stuff) and serve also as NAS since they're able to. A64 is rather limited in this regard due to lack of bandwidth.
Yeah I guess I should have qualified that a bit better. I've had a linux server of some sort under my roof since 2000. They never cost more than $450 to build and performance compared to a SBC... yeah no comparing.
Making the argument that say I needed a small samba based NAS, say 4tb and say we use the same drive and headless config between an X86 and SBC, the savings, is likely going to be maybe $50-75 after you build comparably reliable systems. If a mature SBC was used it would be worth it, but with Pine64 its still wayyyy to immature for me to trust even with disposable data.
Now if I needed gpio capability for additional pieces, well then SBC would have a shot.
Samba Server - by nomadewolf - 05-10-2016, 11:43 AM
RE: Samba Server - by jl_678 - 05-10-2016, 11:58 AM
RE: Samba Server - by rahlquist - 05-10-2016, 12:51 PM
RE: Samba Server - by longsleep - 05-10-2016, 12:26 PM
RE: Samba Server - by nomadewolf - 05-10-2016, 01:11 PM
RE: Samba Server - by longsleep - 05-10-2016, 02:20 PM
RE: Samba Server - by nomadewolf - 05-10-2016, 04:39 PM
RE: Samba Server - by tkaiser - 05-10-2016, 11:48 PM
RE: Samba Server - by nomadewolf - 05-11-2016, 04:49 AM
RE: Samba Server - by tkaiser - 05-11-2016, 09:07 AM
RE: Samba Server - by longsleep - 05-10-2016, 11:25 PM
RE: Samba Server - by rahlquist - 05-11-2016, 10:28 AM
RE: Samba Server - by tkaiser - 05-11-2016, 11:55 AM
RE: Samba Server - by rahlquist - 05-11-2016, 12:40 PM
RE: Samba Server - by tkaiser - 05-12-2016, 03:41 AM
RE: Samba Server - by rahlquist - 05-12-2016, 06:18 AM
RE: Samba Server - by tkaiser - 05-12-2016, 07:25 AM
RE: Samba Server - by nomadewolf - 05-14-2016, 03:52 AM
  need help, looking to setup NAS server over OpenWRT subbu 0 2,577 05-26-2018, 07:48 AM
Last Post: subbu
  Making a DVD Server (including burning) using Rock64 Ron Piggott 1 3,179 04-11-2018, 08:33 AM
Last Post: dkryder
  Linux Web Server OS harcrow 2 5,710 01-30-2018, 10:26 AM
Last Post: Rustproof
Rainbow automatic proxy server Brainmore 0 2,111 01-10-2018, 10:56 PM
Last Post: Brainmore
  Nas Server 4k OriFeniX 0 2,746 10-11-2016, 04:38 AM
Last Post: OriFeniX
  Basic Pine64 Server Set-Up Guide rallar8 1 4,482 08-12-2016, 10:06 PM
Last Post: MarkHaysHarris777
  Making a Ubuntu Server image for SD Card insignia96 3 6,510 04-06-2016, 09:46 PM
Last Post: insignia96
  NAS, Plex Server Crispin 2 5,515 02-26-2016, 04:52 AM
Last Post: Lost13
  Pine64 can run Ubuntu Server Arm, Ubuntu 15.10 minple 23 39,675 12-27-2015, 10:35 PM
Last Post: khgoh
