Missing Screws
Someone in this thread used M2 machine screws:
https://forum.pine64.org/showthread.php?tid=8846
The ones in front are 3mm long, not 4mm.
https://www.laptopscrews.com/M2x3.htm
https://www.laptopscrews.com/Sizing.htm
"The actual diameter of an M3 screw is usually about 2.9mm, an M2.5 screw is 2.4mm and an M2 is 1.9mm."
About consistent with the diameter I'm reading.
Official product:
https://store.pine64.org/?product=pinebo...-10-pieces
$1 + $12 shipping to US.
Looking at the laptopscrews.com page, I'm getting the idea. This was raised with pine64 before, and the reason why they don't just provide "the spec" is, to get exactly the right head diameter, head length, head angle, &c, the spec would be something like "Ningbo Screw Company #2456046464-A, minimum purchase 10,000 units".
Missing Screws - by missingchip - 06-03-2020, 06:17 PM
RE: Missing Screws - by Dendrocalamus64 - 06-04-2020, 03:28 AM
RE: Missing Screws - by missingchip - 06-06-2020, 04:08 PM
  wifi missing some networks filip 0 758 03-11-2023, 03:21 PM
Last Post: filip
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,665 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Screws on bottom case coming loose quadrantids 8 8,215 01-20-2021, 03:47 AM
Last Post: quadrantids
  Screws and Spacers belfastraven 11 14,048 10-13-2020, 09:57 AM
Last Post: feoh
  Lid magnet missing? ModemBlaster 18 19,160 10-13-2020, 08:39 AM
Last Post: PineyMike
  wlan0 missing dex357 6 8,669 06-08-2020, 09:01 AM
Last Post: dex357
  Alternative to the screws? MIchael 10 14,187 03-12-2020, 08:46 AM
Last Post: ab1jx
  Pinebook missing screw from the factory tso4ev 4 6,378 01-20-2020, 01:25 PM
Last Post: Arwen
