How's 2.4 GHz Wi-Fi Working for You?
One thing I've noticed on my Pinebook Pro ever since launch is that the 2.4 GHz-band wireless networking appears to be very, very unreliable. It initially works on first connect, but then goes completely dead for long periods with only brief moments of functioning in between, leading to intermittent connections with lots of dropped packets. It feels almost like it's overheating, but I can't quite figure out how to test that. It happens pretty much regardless of signal strength, and on every network and access point I've tried. 5 GHz-band wireless works fine, and has no apparent reliability issues. Curiously, Bluetooth does not appear to have these issues either, despite using the same 2.4 GHz frequency band and presumably similar functionality on the same transceiver chip.
Are others having these 2.4 GHz-specific issues as well? Is anything known about what might be causing them?
Intuitively, I wonder if the antenna in use on the Pinebook Pro is just not well-matched for 2.4 GHz use, and as a result, transmitting on that band is causing the RF energy to mostly get dissipated as heat in the transceiver and cause problems, rather than being radiated. I don't really have much evidence for this, though, and Bluetooth seems to work a little too well for that to actually be the case. Hmm...
How's 2.4 GHz Wi-Fi Working for You? - by diodelass - 06-01-2020, 10:13 AM
RE: How's 2.4 GHz Wi-Fi Working for You? - by ovv - 06-05-2020, 02:13 PM
  New Working nVME gilwood 0 204 02-12-2024, 08:46 AM
Last Post: gilwood
  keyboard and usb ports not working User 24565 3 2,656 02-15-2022, 10:12 AM
  UART switch not working [EDIT: I got it working] kileel 5 3,521 10-24-2021, 11:17 PM
  pinebook pro trackpad randomly stops working chewie 5 5,808 08-10-2021, 04:33 PM
Last Post: chewie
  Some Keys No Longer Working pietenpol 0 1,739 06-05-2021, 05:39 PM
Last Post: pietenpol
Question External Monitor not Working sciolus 5 5,030 05-05-2021, 02:05 AM
Last Post: aurora.borealis
  Some keyboard keys not working oddsocks 10 10,727 04-20-2021, 08:33 AM
Last Post: dsimic
  Microphone not working on Pinebook Pro vfr400racer 2 4,043 03-21-2021, 02:56 AM
Last Post: vfr400racer
  Anyone have a microphone working on a Pinebook Pro? Rachel Stone 5 4,810 02-20-2021, 05:21 AM
Last Post: dsimic
  Brand-new Pinebook Pro - keyboard not working guy100 8 10,520 10-09-2020, 10:49 AM
Last Post: guy100
