Issues with volume up button
I've recently started playing with my BH pinephone. Unfortunately it seems my Volume up button is unresponsive at best.
Has anyone else had any similar experience?
It seems like the button is not making proper contact, however I am unsure on how to remove the back cover properly there seems to be more to it than just unscrewing the screws.
Any help is greatly appreciated.
There are clips as well as screws. Once you've removed the screws you should be able to separate the plastic parts slightly somewhere, then put a fingernail or a thin piece of stiff plastic in the gap and slide along the join to separate the parts. The imitation credit cards in junk mail are good for this. Having said that I'm not sure there's much you can do other than reseat the connector for the buttons - maybe it'll help. Good luck.
  Multiple issues with the Pinephone MTXP 12 2,322 12-28-2023, 07:55 AM
Last Post: MTXP
  volume down button issue sapphire 0 413 05-20-2023, 06:25 AM
Last Post: sapphire
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,463 05-10-2023, 03:31 AM
Last Post: fxc
  New Phone Opening Issues LuluFrance 5 2,168 03-15-2023, 05:33 AM
Last Post: anonymous
  reset button under back cover, below the camera mruser1 2 1,018 01-02-2023, 08:07 AM
Last Post: wibble
  PinePhone sound issues Chief 4 2,832 07-05-2022, 07:58 PM
Last Post: Chief
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,530 06-23-2022, 02:44 PM
Last Post: zer0sig
  Pinephone 64 Issues of a new user US Notheast as of April 2022 scrwbigtek 9 5,498 05-03-2022, 04:18 PM
Last Post: scrwbigtek
  Pine Phone Pro issues gmastap 4 2,747 03-21-2022, 12:46 PM
Last Post: bcnaz
  u-boot multiboot issues m4xx3d0ut 0 1,120 02-24-2022, 05:11 PM
Last Post: m4xx3d0ut
