Connected to Wifi but no Internet
After not using my Pine A64 for a while, I decided to dust it off and reinstall Android 6.0. I actually first install Adroid TV (v7 I believe), but my wifi kept getting disconnected. Anyhow, I'm able to connect to wifi but it's showing I don't have internet. My other devices are connected to the same network and they are fine. I tried searching online for resolution but I can't find what I need. Please help!
(04-12-2020, 07:31 PM)pnoyrocket Wrote: After not using my Pine A64 for a while, I decided to dust it off and reinstall Android 6.0. I actually first install Adroid TV (v7 I believe), but my wifi kept getting disconnected. Anyhow, I'm able to connect to wifi but it's showing I don't have internet. My other devices are connected to the same network and they are fine. I tried searching online for resolution but I can't find what I need. Please help!
Make sure that antenna attached to Wifi/BT module properly and don't stick antenna on metal surface. Your issue may due to weak signal.
i have been having the same issue with my wifi on my pine64 LTS too, i even tried covering the antenna with masking tape, at first i was thinking i broke the module or antenna so i got another 1 but it does the same thing with a new 1
  Pine 64 + WIFI - OVERHEAT problem Berkut 0 4,910 10-24-2018, 12:52 PM
Last Post: Berkut
  WIFI on Android OS Berkut 2 7,929 10-08-2018, 09:59 PM
Last Post: Berkut
  Want to buy Pine 64 w WiFi, android, replace TV PCs dmcdivitt 3 6,636 12-27-2016, 11:54 PM
  Guest Account Cannot Access Internet on Remix OS and Android x-86 OS deniyulianti 1 4,236 10-21-2016, 05:38 AM
Last Post: MarkHaysHarris777
  Guest Account in Android x-86 OS cannot Access Internet deniyulianti 0 2,907 10-15-2016, 07:30 AM
Last Post: deniyulianti
  I can get Internet Access, Though I cannot Use Instant Messagings (LINE, Zalo, Viber) deniyulianti 0 2,979 10-15-2016, 07:29 AM
  I can get Internet Connection, However I cannot download APK File (Kitkat and Lollipo deniyulianti 0 3,047 10-15-2016, 07:28 AM
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 0 3,326 10-15-2016, 06:32 AM
  Accessing USB drive connected to PINE64 matsunorij 7 13,391 08-05-2016, 08:44 AM
Last Post: matsunorij
  original Wifi module on android 5.1.1 20160505 galbez 3 6,478 07-22-2016, 01:23 PM
Last Post: jodybrown99
