Help analyze COVID-19 with ARM and Android
Rosetta@home has been updated for ARM64 and Android.
4GB RAM needed.
On my LG G5 I had to set a higher RAM limit (not sure if I had set it previously) in the app.
Next I'm going to test on the Pinebook Pro.
https://www.tomshardware.com/news/fight-...ta-at-home
TNGrid has added COVID work units as well. I think the RAM requirement is lower (some are running on my A64+ right now)
(04-07-2020, 06:21 AM)tophneal Wrote: TNGrid has added COVID work units as well. I think the RAM requirement is lower (some are running on my A64+ right now)
You are correct, but 2GB might be pushing it.
Here it says you need to tweak some stuff to run on the Pi4.
https://www.cnx-software.com/2020/04/06/...-covid-19/
My Rock64 is getting plenty of Rosetta work units, but what's going to the A64+ seems to be TNGrid, judging from --get_tasks. It's definitely below the threshold for Rosetta.
I have it running on my Pinebook Pro.
Warning! The default settings will try to run 6 tasks simultaneously and that is too much for the Pinebook Pro.
4 tasks already feels as if the Pinebook Pro will melt.
Now I have 5 tasks suspended and set it to no new tasks.
Don't let it run unattended when you don't know what you are doing!
  google will take control of android in the future. zetabeta 22 15,135 08-25-2025, 03:14 PM
Last Post: zetabeta
  How to install Android on SOQuartz Lenzer 1 2,675 02-17-2025, 01:26 AM
Last Post: LucasNathann
  Android OS that supports LCD touch panel (pine a64) Spekboy 0 1,538 01-14-2024, 01:41 PM
Last Post: Spekboy
  Android phones run on a linux kernel tg121268 0 3,092 07-17-2020, 07:30 PM
Last Post: tg121268
  Cant access pine64 subsites on android butchi91 1 4,033 05-05-2020, 01:51 PM
Last Post: Danct12
Question Android Touchscreen Kiosk cymrow 1 5,906 09-26-2019, 09:26 PM
  Pinetab dual boot Linux and Android libergm 2 5,747 07-10-2019, 10:49 AM
Last Post: libergm
  Android 5.1 ??? Matroxplay 2 5,889 07-14-2018, 11:36 AM
