Retropie on Pinephone
I borked my system and now the pinephone only boots to a blank screen. So I'll take this opportunity to reinstall retropie and record my steps as I go.
Edit: Moved the installation instructions into post #3
Notes: Emulationstation will launch games on a fresh install but fiddling with retroarch config settings seems to break it. The xmb menu driver for retroarch frontend was previously fast but unresponsive after reinstall. I was unable to get to the bottom of it so change the menu driver to rgui to avoid the headache. Select the terminal keyboard on squeekboard and the default keys for navigating the menu are capital W and X for left/right, F4 for enter, capital Z for down and the up arrow key for Up. Capital P and O are select/back keys. Disable audio-sync and video vsync settings for best emulation performance. Enable sync to content frame-rate to deal with overspeed. Select tinyalsa for audio driver to minimise stutter.
Extra: The xmb menu lag was caused by installing assets, ie the menu icons. Looks like you can disable shadows, smoothing, etc but simplest option is to uninstall the assets. Go to the configuration tool in the retropie script menu and uninstall them from there.
does retroarch has a mobile UI with on screen controls??? i Know in android it has but i dont know if that is a separated android implementation only....
(05-06-2020, 05:50 AM)paju1986 Wrote: does retroarch has a mobile UI with on screen controls?
I'm not a fan of touchscreen controls but should be possible according to this link - I haven't got retroarch installed currently so unable to test.
Edit: The joypad overlay shows up but probably need to remap the keys to make it work.
.jpg   retroarch-virtualpad.jpg (Size: 62.36 KB / Downloads: 563)
  Movuan distribution for PinePhone merom 5 4,675 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,030 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Latest firmware for PinePhone modem! Subsentient 105 198,982 02-02-2025, 08:47 PM
Last Post: bacydentir85
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 53,903 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,302 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 58,433 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 5,585 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 14,831 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 3,788 06-16-2024, 10:26 PM
  Possible Free Backup Carrier for PinePhone PineFone 0 3,681 06-13-2024, 03:45 PM
Last Post: PineFone
