Fedora + Phosh for PinePhone
#61
(06-23-2021, 09:36 PM)Alho Wrote:
(06-23-2021, 02:20 PM)ppuser199 Wrote: Thanks - Will report back once a new image is available.
New build up (F35). Logs seems to indicate it should be ok now.
New F34 build will be available in a few hours.
All untested (aka nightlies) feedback very welcome
Hi Alho - Definitely appreciate you fixing the f35 nightly image build.  The 2021-06-24 F35 image boots and works fine on a pinephone.  Bonus: Auto-rotation works... :-)
Tried both latest  F34 and F35 but don't get any sound at all..I do like the Pboot solution to boot both emmc or sdcard, makes it much easyer.  when being called it does tril..btw
Anyone else with this issue?
on [url=https://github.com/nikhiljha][/url]PP-fedora-setup audio is ok
It seems we ran into a bunch of weird pipewire updates, that didn't do what it should.
Try to make a full dnf update, and after that run:
systemctl enable --now --user pipewire-media-session
as your normal user.
That fixed it for me.
(07-17-2021, 01:06 PM)Alho Wrote: It seems we ran into a bunch of weird pipewire updates, that didn't do what it should.
Hi Alho,
thank you for your reply, just gave a try with above systemctl but that didn't work unfortunately,
settings show analog output driver, compared to Manjaro phosh 12 which gives choice between call quality or high quality
right now running F35 14-7, tried the 17-7 and 15-7 with ext4 partition, not booting at all...
Right, something goofed up the build system 4 days ago - so last 4 images were useless (deleted now). I'll make some new ones to test in a few hours.
Todays image (18/7) is missing a package. Run sudo dnf install alsa-ucm to add it.
You may have to do the systemctl... mentioned earlier too - and then a reboot.
Just flashed 19/7 and it looks like alsa-ucm is already installed so I did a systemctl and after a reboot, Yes!! audio is working now, well done.
One thing I'd like to upgrade is Phosh, curently 0.11.0-1 to 0.12 but I don't see it yet in the repos..
https://source.puri.sm/Librem5/phosh
was wondering if I could compile it and update the existing one..?
(07-19-2021, 02:06 AM)wizmart Wrote: Just flashed 19/7 and it looks like alsa-ucm is already installed so I did a systemctl and after a reboot,  Yes!! audio is working now, well done.
The new Phosh update needs glib 2.69 . We are waiting for that to hit the fedora repos, then Phosh will be updated too.
Hi Alho,
I just found a post about Anbox-halium or Waydroid which is an updated Anbox to LineageOS 17.1, been dreaming about it...
https://linuxsmartphones.com/waydroid-le...han-anbox/
https://github.com/Anbox-halium/anbox-halium
So I tried to build it as mentioned in github but I got stuck at "repo sync" runnig out of space after taking 10g!!  I wonder how big is the repo...
anyway I free up some space on my 32g sdcard and I'll give soon another try .
If you ever decide/manage to build it, could you include it maybe in one of your future build...? or tell me how you did it
btw, Phosh got updated to 0.12 finally no more sensor black screen..!
Edit: well didn't need to build it, just had to run the script install but when I tried to run Anbox container get the msg binder and ashmem not found..
so which kernel has binder and ashmem on aarch64 remains the question, still looking around..
(07-26-2021, 04:57 AM)wizmart Wrote: Hi Alho,
I found a video of someone running Minecraft through Waydroid on a Pinephone (3GB). More info in the description.
https://youtu.be/Pe6uVKRBbCM
  Using Signal on PinePhone in mid-2023? dante404 47 14,021 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,571 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,193 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 536 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,513 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,887 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,155 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 103,171 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,053 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,426 10-24-2023, 08:57 AM
