05-06-2016, 07:00 PM
Check your router ip table to see what ip your pine64 is using after the update.
SSH for noobs on Debian
05-07-2016, 04:51 AM
(05-06-2016, 06:41 AM)Luke Wrote: Yes, I dont think that root comes with a password; the default user (pine64user) is a sudoer I am using PuTTY so it doesn't prompt you for the username until the connection is made, and as I've said before the PINE64 was actively refusing connections so there was no login prompt (username or password). (05-06-2016, 07:04 AM)rahlquist Wrote: KuJoe, Yes, 100% positive. This was the first time I've powered on the PINE64 and so I was logged into the router and saw the IP it was assigned and then I made a static entry for the PINE64. Rebooted it multiple times and could ping it each time. (05-06-2016, 10:28 AM)Luke Wrote: yea, this too. You may be connecting to a previous IP Since this was the first time I powered the device on there was no previous IP unfortunately. (05-06-2016, 07:00 PM)Leoncito81 Wrote: Check your router ip table to see what ip your pine64 is using after the update. What update? There hasn't been any changes to my PINE64.
05-07-2016, 08:02 AM
(This post was last modified: 05-07-2016, 08:03 AM by Leoncito81.)
Try installing MinGW. (www.mingw.org). It will give you a minimal Linux shell to be able to control the pine64.
Then you can use SSH through the Linux shell. It will prompt you. |
Arch, Debian or other for Pinebook? | cootcraig | 3 | 6,247 |
05-01-2019, 09:11 AM Last Post: cootcraig |
Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) | Quintus23M | 9 | 16,849 |
02-03-2017, 05:50 AM Last Post: pfeerick |
Netatalk on Debian | pictus | 10 | 13,665 |
09-28-2016, 08:01 AM Last Post: wojciech_czyz |
How to make multicast working on ubuntu and debian | brengthdom | 3 | 6,996 |
09-18-2016, 02:05 PM Last Post: brengthdom |
Debian (Raspbian-like) | Pander | 15 | 22,235 |
04-09-2016, 08:40 PM Last Post: lenny.raposo-pine64.pro |
Minimal 64bit ARM RootFS for Debian and Ubuntu | umiddelb | 46 | 64,472 |
03-06-2016, 10:28 AM Last Post: umiddelb |
1st Debian image and further information | umiddelb | 13 | 20,543 |
03-04-2016, 02:08 AM Last Post: umiddelb |
