PinePhone RTL8723CS automatic test fail and WiFi problem
I run automated tests RTL8723CS is failing.
https://wiki.pine64.org/index.php/PinePhone
If RTL8723CS is failing:
"make sure there is Wifi router around 5 meter area when perform this test, the Wifi test function sniff for SSID to determine test result during autotest. The Wifi can fail if the battery power is too low. "
I tried with battery full and charger on but still automatic tests fail and there should be Wifi signals around.
And I have not got WiFi working with Ubports or Manjaro Alpha3.
Any one else having this problem?
Any ideas how to get it to work?
Or is the HW just faulty?
(02-13-2020, 05:58 AM)surfingtux Wrote: I run automated tests RTL8723CS is failing.
I think I remember someone else with the same problem got it to work by flicking the privacy switches from off to on and back again, YMMV.
(02-13-2020, 04:10 PM)pjsf Wrote: I think I remember someone else with the same problem got it to work by flicking the privacy switches from off to on and back again, YMMV.
Earlier I had tried once to flick switches on/off and tried also to run tests when switch is off.
Now I tried multiple times but no success. Sad
Thanks for the tip. Maybe this might still help someone else.
My PinePhone failed the test for the RTL8723CS at first but after being plugged in and charging for about an hour I tried it again and now it passes. Still fails the EG25 test so I will continue to look into that.
PinePhone BraveHeart Edition
Pinephone Convergence
PineTab
RockPro64
(02-19-2020, 12:11 AM)publiclewdness Wrote: My PinePhone failed the test for the RTL8723CS at first but after being plugged in and charging for about an hour I tried it again and now it passes. Still fails the EG25 test so I will continue to look into that.
For EG25:
Do you have sim card inserted?
https://wiki.pine64.org/index.php/PinePh...quirements
and
discussion around that issue:
https://forum.pine64.org/showthread.php?tid=8991
  PinePhone - boot from microSD laserpyramid 6 531 Yesterday, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 335 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 226 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,807 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,771 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 595 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,331 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 488 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,670 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,928 12-04-2023, 02:14 AM
Last Post: Peter Gamma
