(03-29-2020, 11:34 AM)fpb4 Wrote: Boots, stands by a perfectly visible lock screen, unlock, diplays phosh GUI for a couple seconds and dims to a dark screen
Slowly "dims" ?
What's the content of /sys/devices/platform/soc/1c2b000.i2c/i2c-1/1-0048/iio:device1/in_proximity_raw ?
And what happens if you delete file /etc/udev/rules.d/10-proximity.rules ?
I haven't updated for about a week but this might be relevant:: if you place your hand over the top of the phone, it slowly dims to black (unresponsive to keyboard/touch while it's happening) until you remove your hand. Overzealous light sensor setup?
(03-29-2020, 12:38 PM)nas Wrote: I haven't updated for about a week but this might be relevant:: if you place your hand over the top of the phone, it slowly dims to black (unresponsive to keyboard/touch while it's happening) until you remove your hand. Overzealous light sensor setup?
Interesting, I´ll try to reproduce later. If the lightsensor already is working and makes the touchscreen unresponsive,  then making it active only during calls should not be far away.
"- is there already a tool for overclocking it desperately?"
Slowly "dims" ?
Removing the udev rule did the trick - cheers!
Couldn't get in_proximity_raw initial value, but once booted without the rule it's set to 2443.
(03-28-2020, 10:52 AM)buffer Wrote: dd should work just as good as etcher.
Has anyone tried earbuds with the built-in microphone? That's all I have, I don't have a headset and I was wondering if it works on images:
1) pre-March 22
2) March 22 or later
Waiting for Monday so I can try a usable image.
BTW I think @bcnaz seems to imply he's been running apt update, I'm installing image from dd every single time.
Nope :  where did you read that ?
Fresh Download & install with each 'new release'   or  re-Flash/& reinstall if I Bork the OS...
  ( I am using Balena Etcher exclusively)
   >  I did have a problem when I "attempted" to do the update recently. <
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Quick overview of Sunday March 29, 2020 release :
  So phone calls out and receives calls,  very good audio, enough volume even for me.
       (My hearing is not great)
 Sending and receiving text messages.
  I have not tested the contact book on this release yet,   ( I will be trying that shortly )
The wifi works "out of the box"
The addition of Firefox ESR is a nice step,  it could use a little fine tuning on the scaling.
My data is still not working, but I suspect I have a sim card problem there,  still waiting on the new replacement one
   being shipped by AT&T....
  I ran the the update(s) as notified by 'Software'  that went smooth.
  ** >  SURPRISE  the speaker phone function is working !  Nice,  but,  that could use a bit more volume there.
    Thank You for all your efforts  !!!
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Aww,
       Contact book appears to be non-functioning  ?
tried un-installing and reinstalling,  no difference..?
Edit :
Soo, I can recieve text and reply to text messages, BUT I cannot use the contact book..!
There for I cannot label who they are from, just the phone number appears...
I CANNOT originate any texts !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Yup love how this is developing, but I still think there is a bug in connecting Nextcloud accounts. I went back to debian-pinephone-20200309.img.gz  Once I had set up the account, when I go to contacts I am given the option to use the Nextcloud account and when I go to the Calendar the Nextcloud Calendars are already there,
J
Yes I can confirm the same. Nextcloud contacts are not present
Sent from my iPhone using Tapatalk
@a-wai and everyone else, I kinda figure out how to have Firefox emulate mobile mode. Hamburger menu -> developer tools -> responsive design mode:
From here, the first drop-down on the left -> iPhone 6/7/8 Plus.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,997 03-25-2024, 09:07 AM
Last Post: anonymous
  unofficial kali linux for pinephone help needed pinesmell 5 3,626 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Auto start application on Phosh login Zebulon Walton 8 3,357 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,352 08-31-2023, 12:38 PM
Last Post: vusra
  Has anyone got briar-desktop running on mobian? vusra 5 3,013 06-19-2023, 03:02 PM
Last Post: vusra
  Using sway along phosh fdlamotte 2 3,307 05-11-2023, 04:24 PM
Last Post: kabouik
  Axolotl on PinePhone / Mobian arno_nuehm 219 165,308 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,327 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,171 03-01-2023, 04:45 PM
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,781 02-24-2023, 12:11 AM
Last Post: nexion
