kernel build script for latest mainline manjaro kernel
#21
I'll reply to your hwaccel comments in the other thread to keep things separate.
i've made a diff of linux next20200529 and tsys' latest linux-pinebook-pro updates (branch 5.7-rc7). anticipating 5.7 released shortly!
here is the patch, more details about hwaccel patches in the other thread.
linux next20200529 pinebookpro patch: https://pastebin.com/YK4LXeyv
@xmixahlx I compiled 5.7 with your config but USB-C charging does not work. Do you have similar problems ?
good question. i have been using the barrel charger lately, i will test. this thread needs to be updated. too...
Running this on Debian Buster. kernel-package is not a known package but doesn't seem needed. Additional packages are rsync libssl-dev:native
So far things are looking good. The screen was dim, but that's easily fixed.
Quick question about the state of suspend in the mainline 5.6. Is this true suspend or is this suspend to idle? Please note, I used the unofficial Debian installer to install my initial system.
tsys confirmed that usb-c charging is now fixed in his own thread now. try again.
i believe it is s2idle, but i was using about 2% battery overnight prior to installing my nvme ssd drive. now i've disabled suspend since it doesn't work on nvme...
@xmixahlx - I've seen this thread. I'm gonna give it a try today.
(06-07-2020, 02:39 AM)as400 Wrote: @xmixahlx - I've seen this thread. I'm gonna give it a try today.
It works Smile
excellent! i confirmed it worked in the default branch, and then rebuilt the hwaccel kernel. thanks for reporting. i moved my usual setup into my office and was using the barrel connector, so had no idea it was broken, lol.
updated the script in the first post for v5.7.
  How to update Manjaro to 20.10 pineitup 6 2,194 01-04-2021, 02:00 PM
Last Post: nightranger73
  Make your own Manjaro image flatulent_piney 0 810 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 1,792 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 857 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 839 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 3,293 07-13-2020, 03:13 AM
Last Post: brent.thierens
  full disk encryption with luks on manjaro xfce limxr 48 23,107 07-09-2020, 07:27 AM
Last Post: JtR
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 2,434 06-23-2020, 12:41 AM
Last Post: pljanson
  mesa-git build script for latest panfrost xmixahlx 28 18,087 06-11-2020, 11:16 PM
Last Post: xmixahlx
  How to boot Manjaro from NVME with uboot on eMMC as400 47 18,224 06-07-2020, 02:37 AM
Last Post: as400
