Debian MATE update v1.6
For those running the default Debian image, Mrfixit has just released the v1.6 update, bringing an updated kernel (4.4.205) and graphical fixes for the included Firefox version.
Use the updater applet in the notification tray to update. Smile
(12-02-2019, 10:23 AM)fire219 Wrote: For those running the default Debian image, Mrfixit has just released the v1.6 update, bringing an updated kernel (4.4.205) and graphical fixes for the included Firefox version.
I lost the applet button when moving panels around. Does it do the same as sudo apt update && sudo apt dist-upgrade?
If not, what's the command to run the applet?
Thanks in advance
Thanks in advance
Looks like the command is:
mate-terminal -x sudo /usr/bin/mrfixit_update.sh
From a open terminal just "sudo /usr/bin/mrfixit_update.sh"
de KL7JKC
Terrific! Thanks!
Is anyone else finding that the script hangs on 'Adding bluetooth packages to fix issues...'?
It won't go beyond that for me.
(01-17-2020, 04:47 PM)ToPort Wrote: Is anyone else finding that the script hangs on 'Adding bluetooth packages to fix issues...'?
I waited for a long time then pressed the Enter key to see if it was possibly waiting for input?
Shortly after that the script completed normally.
Coincidence - you tell me?
Yeah, looks like a lack of patience on my part may have been the issue.
Of course often nothing solves a problem quite as efficiently as posting on a forum, then looking like an idiot...
Does the v1.6 update also switch to the Debian Buster repositories?
My Logs. It's a long list. Anything I can do about it?
.png   Logs2020-03-31 08-52-50.png (Size: 363.53 KB / Downloads: 398)
  Debian on Pinebook Pro u974615 7 993 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 318 03-01-2024, 06:46 PM
Last Post: Puckla
  install debian on pbp jsch 7 4,024 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,378 09-07-2023, 09:38 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,018 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,032 07-15-2023, 02:58 PM
Last Post: u974615
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 1,334 05-10-2023, 04:51 AM
Last Post: Vinay
  Manjaro update broke hardware video acceleration with mpv myself600 2 1,342 01-25-2023, 09:12 AM
Last Post: myself600
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,274 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,333 12-09-2022, 05:04 AM
Last Post: ndp
