Issues connecting bluetooth headphones and speakers
I am having a problem getting bluetooth headphones and speakers to connect using the default OS.  They pair without a problem, but always fail when connecting to audio sink.  The error I receive is "Device added successfully, but failed to connect."  I've tried two sets of headphones and two speakers and get the same error with each one.  Is there a workaround or fix available?
You need to install the package pulseaudio-module-bluetooth to be able to use bluetooth headsets.
a simple
sudo apt-get install pulseaudio-module-bluetooth
will do the magic.
Thank you. Worked perfectly.
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 906 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Pro wants a PIN for my bluetooth mouse ColoBill 1 695 01-19-2025, 04:38 PM
Last Post: ColoBill
  Audio Issues alvinsmith 1 1,071 08-10-2024, 01:50 AM
Last Post: sparkie
  Issues with T-Mobile Home Internet? skinnyonthebebop 3 2,527 10-17-2023, 07:42 AM
Last Post: skinnyonthebebop
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 2,799 10-01-2022, 10:16 AM
Last Post: crazyquark
  MiniConda Install Issues nixyhustle 0 1,435 09-16-2022, 10:06 PM
Last Post: nixyhustle
  new PBP issues jpjnh 9 7,216 08-22-2022, 07:26 AM
  how to get rid of heavy distortion from the speakers? stozi 2 3,059 02-20-2022, 05:46 AM
Last Post: stozi
  Issues with External Display After Recent Update reundo 0 2,054 11-18-2021, 06:37 PM
Last Post: reundo
  Up-firing speakers!!! mamboman777 6 7,585 07-28-2021, 02:54 PM
Last Post: mamboman777
