Can I boot system from nvme SSD?
I'd like to know if I can boot up system on nvme SSD.
I may a little faster.
No;
https://wiki.pine64.org/index.php/Pinebo...Me_adapter
https://wiki.pine64.org/index.php/Pinebo...le_Storage
That said, you can boot a kernel off eMMC or SD card, which then mounts the root FS, (and any other FS selected by that OS), from NMVe. There are misc. instructions on how others made it work here in the forums. It's nothing an experienced Linux person would have trouble with. But, it's not ready for prime time for the average Linux user.
It's likely that in a year we would be able to boot off SPI, (a small flash drive builtin to the Pinebook Pro). Then it could boot the NVMe. That's no where near certain, nor complete.
Arwen Evenstar
Princess of Rivendale
Quote:It's likely that in a year we would be able to boot off SPI, (a small flash drive builtin to the Pinebook Pro). Then it could boot the NVMe. That's no where near certain, nor complete.
it's not like uboot transferred from eMMC/SD to SPI magically starts to understand PCIe/NVMHCI, support for the latter should be written, no matter where the code resides. So this is the answer to the poster - you would be able to do so, if the firmware used, did support that interface. it's doesn't yet. so try using that rootfs on NVMe SSD approach, suggested above.
ANT - my hobby OS for x86 and ARM.
Someone did modify u-boot to allow booting from NVMe, and I believe a few people tested flashing it to SPI with success. The thread's probably buried, but it should be linked in the wiki.
(01-11-2020, 09:49 PM)tophneal Wrote: Someone did modify u-boot to allow booting from NVMe, and I believe a few people tested flashing it to SPI with success. The thread's probably buried, but it should be linked in the wiki.
Do you mean this thread:
https://forum.pine64.org/showthread.php?...4#pid53764 ?
I added a link from the Wiki over a month ago.
If it's some other thread, please let me know.
That's it.
There are also power issues:
Some NVMe drives Can have their maximum power dialed down,
but
Then they may no longer have such a speed advantage.
Disappointing for sure,  I now have the parts to convert two PBP's,
But I think I will stay with the eMMC,  Unless someone can Prove it is a worthwhile change.
**  Even If you get it working, you may have to keep your A/C connected or Kill the battery in a short time !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  uboot wont boot to SD card after upgrade jbradley419 7 785 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 285 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,195 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 674 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 577 11-22-2023, 11:47 AM
Last Post: fxc
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 753 09-27-2023, 08:53 PM
Last Post: pinemouth
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,158 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,852 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 795 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,921 06-14-2023, 07:20 AM
