11-14-2019, 05:03 AM
I got manjaro arm booting to a full DE (mate). For the moment no sound and no wifi but everything else seems to work. Didn't test if the usb3 port is working as usb2 or usb3.
Manjaro Arm on the pineH64
01-11-2020, 04:53 AM
Cool stuff, have you made any progress?
Are the folks at manjaro-arm going to add the H64 to their manjaro-arm-installer script?
01-13-2020, 07:56 AM
I didn't have time yet to do further research. Especially because it was just during the change over from linux 5.3 to 5.4.
I had the necessary patches for linux5.3 to get wifi and hdmi-sound working so it shouldn't be a big deal. I can provide you the packagebuild for U-boot for the h64. In fact it's just building the image for the A64 an remove u-boot from the project file and inject the u-boot for the H64 in the image. To get wifi and hdmi-sound working it's editing the dtb for the h64 and build a new dtb. You should then replace the old dtb with the new one. I don't think they have the intention to make it official as nobody is interested in this.
02-06-2020, 01:03 PM
Cheers, I was hoping that Manjaro would pick up on this as they do an excellent job with the image for the PinebookPro. But I think I rather wait for Armbian to get the eMMC support sorted, which is a bit flaky at the moment, and use their image.
03-16-2020, 04:30 AM
Hi @roel, have you used Manjaro on the Pine H64 recently by any chance? How would I go about installing? Thanks for any help
PinePhone (BH 2GB + CE 3GB) // RockPro64 4GB (rev. 2.1) - OMV NAS // PineH64 3GB (model B) - off-prem OMV NAS // Pine64-LTS 2GB (rev. 1.2 + Playbox) - Domotics server
03-27-2020, 09:38 AM
@p1x3l3d
I didn't upgrade my kernel yet. Normally I should have some time next week to test a new kernel. Normally usb3 should work out of the box on the latest kernel. I don't know if the wifi bug is still there, the hdmi-sound is only enabling it in the dtb.
04-02-2020, 02:11 PM
Okay, thanks! I'll see if can find some time to tinker about myself
I made a sourceforge page with my builds and modified files for manjaro-arm-tools:
https://sourceforge.net/projects/manjaro-arm-pineh64/ I made a post of it on the Manjaro-arm forum: https://forum.manjaro.org/t/pineh64-mate-image/134606 It works from a micro-sd card, but I couldn't boot it from my odroid emmc. Maybe it works from the official pine64 emmc, but I don't have such a emmc module to test. It runs from the 5.6 kernel, but I didn't implement the usb3 port and the wifi yet in the dtb. From the moment I have a dtb that does the job, I will add it to the sourceforge page.
Official manjaro-arm support fort the pineH64 is added to manjaro-arm-tools. So the only thing you have to do to build your PineH64 image is installing manjaro-arm-tools and the profiles and then running this command (build is approx 10 minutes):
sudo buildarmimg -d pine-h64 -e "your-favourite-de" but change"your favorite DE" by one from the list with supported DE's: ─ cubocore ─ gnome ─ i3 ─ kde-plasma ─ lxqt ─ mate ─ mate-fta ─ minimal ─ plasma-mobile ─ server ─ wayfire ─ xfce
07-02-2020, 03:42 AM
First, many thanks for your effort in getting Manjaro up on the H64 and being added to the manjaro-arm-tools.
I was able to build an image and flashed it onto an eMMC Module, but the board won't boot from eMMC. Attached is a copy of the serial output on UART. Any advice on how to fix this issue? Code: U-Boot SPL 2020.04-1 (May 21 2020 - 19:41:22 +0000) |
Manjaro update to Kernel 5.18 breaks install | as365n4 | 5 | 5,926 |
07-03-2022, 04:02 AM Last Post: as365n4 |
