No sound on PBP default installation
Music
I just received the PBP with preinstalled Debian + Mate. everything is more or less fine, except that the sound doesn't work at all:
 - neither on speakers, nor on headphones
 - in Alsamixer no setting helped me, when trying to set output to default, the Alsamixer aborts and I can't rerun it
 - I tried checking sound from "control panel", I think there is no connection to Pulseaudio (but Pulseaudio is installed)
 - when I play a song (no sound ofcourse), one setting in volume control says that there is no app playing the sounds, although it's playing.
I haven't tried to update anything, I don't know the commands.
I don't know if I need maybe to set that UART switch if set to off, but I need to open the laptop for that. (as in thread https://forum.pine64.org/showthread.php?tid=8231)
I haven't tried it on HDMI, I don't see that port, only UCB-C, if it is meant for HDMI, I have no adapter to try..
I am pretty much a noob in Linux, so any help with an elaborated answer (links to explanations like "how to install or try out a new OS") would be appreciated  Smile
(11-08-2019, 07:03 AM)ivek Wrote: Hi,
Hi ivek,
I received my PBP just yesterday, and also had no sound. Found that "output volume" was set to Mute (under Control Center - Sound Preferences). All good once unchecked. Note: the "test speakers" under hardware does not work.
Apologies if this was really obvious and you have already checked this setting.
Cheers Bruce.
Hi ivek,
Cheers Bruce.
I had the same problem,  there is another thread on this same subject,  Deebeez had a quick & easy fix.....
rather than repeat it I suggest looking at that other thread...
AND  check your audio with real sound like YouTube or something....  The 'Test speaker'  does not seem to work on this OS.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Tx for your help guys, still no luck...
brucec1999 Wrote "Found that "output volume" was set to Mute (under Control Center - Sound Preferences). "
Already been there, in my PBP that option is completely grayed out.. maybe that's a clue  Smile
deebeez Wrote:"[url=https://forum.pine64.org/showthread.php?pid=51960#pid51960][/url]Ok guys. I fixed it. I went to terminal, typed in alsamixer, then f6 to change from default sound to 0 es8316-spk-sound. Hopefully this will help someone else out."
We already tried everything in Alsamixer, not working... when output set to default (from the sound device), alsamixer aborts and can't be started again, as I wrote..
If nothing else works, I will try another Linux, maybe Ubuntu + Cinnamon.. going to buy an McroSD card now
Hi ivek,
Cheers Bruce.
Thanks four your help guys, still no luck
@bruce, All settings in that sound are grayed out, maybe that's a clue Smile
@bcnaz, We already tried turning on everything in Alsamixer, the sound output is set to the only device that could play... if I set it to "default", the Alsamixer aborts and can't be started again...
If nothing helps, I will buy a MicroSD card and try another OS
DID you try it on a site like YouTube ? When I tried the 'TEST' function mine did not work.... But it works on YouTube.
I did also add some alsa software thru synaptic (do not remember the exact names)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
You might want to see this thread:
https://forum.pine64.org/showthread.php?tid=8180
(11-09-2019, 01:16 PM)zaius Wrote: You might want to see this thread:
Small update, tried booting Android, sound is working, so it isn't a hardware problem.
I saw that in some other PBP system image notes, (ayufan's image compatibility list)
Debug UART is Disabled, as it causes sound issues, with boards up to v2.1
Maybe this is needed, just need to figure out how & where to disable it.
Also I will open another thread, to ask how to boot Ubuntu + Cinnamon, if there are some images prepared...
Ok, dumdum - I was logged in as root Big Grin , all the time, that's the first thing I tried when I gotten it, now I'm logged in as the user "rock", sound working without any problem.. update button visible also, and layout is different  Smile
my sound is garbled in both ubuntu and recalbox out of the head phone jack. the uart is off.
Working as a Film Electric and I have been using Linux since around 2002.
Like to play with Python and Jupyter Lab/Notebooks when not going to the park with my baby girl.
  Nethunter default password failed lamlarryyyy 0 78 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  Fedora 37 installation gswatkins 13 4,144 10-18-2023, 07:53 AM
Last Post: poVoq
  Sound on Armbian Bram 1 638 04-01-2023, 03:16 PM
Last Post: TRS-80
  HOW TO create a installation USB with ... (see below) Ice-O-Star 1 823 01-06-2023, 01:02 PM
Last Post: DrYak
  My installation guide starting from messed up eMMC Besouro 0 679 12-19-2022, 01:01 PM
Last Post: Besouro
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 2,405 11-02-2022, 02:33 PM
Last Post: kebab
  Loud distorted speaker sound when connecting to power supply myself600 2 938 09-21-2022, 12:11 PM
Last Post: myself600
  reset sound after suspend to memory (deep sleep) Der Geist der Maschine 16 15,341 10-18-2021, 07:31 PM
Last Post: Syonyk
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 1,627 07-13-2021, 10:37 PM
Last Post: pjsf
  Debian Bullseye installation Baconomics 3 4,580 01-07-2021, 01:46 PM
Last Post: kuleszdl
