Left-side USB 3.0 port not working
I've been having trouble getting my Pinebook Pro's left-hand USB port, the large Type-A one with the blue interior and superspeed pins, to work at all. I can get power from it alright (though no data on whether negotiation is working yet), but nothing I plug into it enumerates or shows up in `lsusb`, nor does `dmesg` show any events. This applies to both USB-2.0-only devices, as well as those that support USB 3.0. The other USB ports - the Type-C one, and the 2.0 Type-A one on the right side, are both working just fine, so I'm suspecting the hardware here. I'm mainly posting this thread to ask if anyone else can confirm that their 3.0 port works, just so we can narrow it down to a spurious defect in my particular unit (one that I, confident with a soldering iron, might repair) or a more general design flaw or firmware bug that needs more professional attention.
So, does your left Type-A USB port work?
(11-07-2019, 07:22 PM)diodelass Wrote: I've been having trouble getting my Pinebook Pro's left-hand USB port, the large Type-A one with the blue interior and superspeed pins, to work at all. I can get power from it alright (though no data on whether negotiation is working yet), but nothing I plug into it enumerates or shows up in `lsusb`, nor does `dmesg` show any events. This applies to both USB-2.0-only devices, as well as those that support USB 3.0. The other USB ports - the Type-C one, and the 2.0 Type-A one on the right side, are both working just fine, so I'm suspecting the hardware here. I'm mainly posting this thread to ask if anyone else can confirm that their 3.0 port works, just so we can narrow it down to a spurious defect in my particular unit (one that I, confident with a soldering iron, might repair) or a more general design flaw or firmware bug that needs more professional attention.
I only tried to plug a mouse receiver in it, and it didn't work. I should probably check if the kernel was compiled with xHCI support.
Could you post what distros you are using ?
(11-07-2019, 11:54 PM)electriccrowbar Wrote: Could you post what distros you are using ?
The default Debian and Ubuntu Bionic.
I think I only tried to use it in Debian, haven't tried Ubuntu. I'll let you know when I have a chance to try.
Default Debian, left usb port mouse Logitech m325 working ok.
Ubuntu Bionic, one of ayufan's images, is what I have now. I didn't get it to work under either this or the factory Debian install, though.
I also had problem with the USB3 not working with the stock debian image (even after updates).
Now it is working after I installed Ubuntu/Mate
  New Working nVME gilwood 0 213 02-12-2024, 08:46 AM
Last Post: gilwood
  HDMI and PBP USB C port IMSAI8080 0 1,100 09-26-2022, 09:17 AM
Last Post: IMSAI8080
  keyboard and usb ports not working User 24565 3 2,673 02-15-2022, 10:12 AM
  UART switch not working [EDIT: I got it working] kileel 5 3,537 10-24-2021, 11:17 PM
  pinebook pro trackpad randomly stops working chewie 5 5,829 08-10-2021, 04:33 PM
Last Post: chewie
  Pinebook Pro Docking Deck Ethernet Port MickTheGeek 1 2,445 06-16-2021, 07:49 PM
Last Post: Kuawi
  Some Keys No Longer Working pietenpol 0 1,745 06-05-2021, 05:39 PM
Last Post: pietenpol
Question External Monitor not Working sciolus 5 5,045 05-05-2021, 02:05 AM
Last Post: aurora.borealis
  Some keyboard keys not working oddsocks 10 10,765 04-20-2021, 08:33 AM
Last Post: dsimic
  Microphone not working on Pinebook Pro vfr400racer 2 4,054 03-21-2021, 02:56 AM
Last Post: vfr400racer
