Rock64 v2 freeze help!
Exclamation
Hi.  Recently I acquired several Rock64 and among them a 4GB board that turns out to be a V2, the problem is when it comes to flashing and starting the board since it freezes and stops working within a few seconds.  I have searched for information on the forum but I can't find a solution.  I need help before resorting to product return.  thanks, sorry for the Google translation ...
Can you give us more information about what you're doing that leads to the ROCK64 freezing?
What software are you trying to run? And what steps are you following to get the software installed?
I have a 4GiB ROCK64 v2 here and can try to duplicate the problem.
Classic signs of faulty power supply. Have you got a different power supply to rule this problem out. Are you booting from SD card. If so you may a flashed a bad image onto the SD card. Try a different image and SD card to rule that out. A little more info on your setup would help too.
I comment a little more detailed. I was currently installing the latest official version of Libreelec for Rock64 which I think is 9,501 if I'm not mistaken. In the rest of the installations that I have done, 2GB boards, I have not had any problems and they are perfect. The "error" occurs within a few seconds of starting Libreelec as soon as it lets me into some options and freezes. I have also tried other SD cards which work perfectly in Rock64 2gb and the same power supply, although I have a new one and this afternoon I will try to see if that was the problem, I do not know if the 4gb board needs more power. I will also try to flash the Rock64 with other images of Android or Linux to see how it goes.
Good evening, this afternoon I have tried rock64 again with the image of Libreelec and another power source and the error is exactly the same ... a few seconds after the start of freezing and does not respond. But later I flashed it again but this time with "Armbian Ubuntu 18.04 Bionic Desktop [microSD / eMMC Boot] [5.90]" and apparently it works fine I haven't installed anything but it doesn't crash. Tomorrow I will do another test with Android 8.1 to see how it goes. And even if it worked, I would like to be able to install Libreelec directly.
I found Armbian to be the most stable. No issues with booting or freezing. You really do need to spend time experimenting with other distros. See what has worked for others and try that. Good to hear that the board is booting so that's the hardware problem resolved.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 1 118 03-18-2024, 06:56 AM
Last Post: diederik
  Rock64 bricked shawwwn 7 5,463 03-17-2024, 12:22 PM
Last Post: dmitrymyadzelets
  Rock64 won't boot luminosity7 10 3,870 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 258 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,772 04-29-2023, 04:24 AM
Last Post: newestssd
  OpenWRT on the Rock64 CanadianBacon 12 7,809 04-24-2023, 12:40 PM
Last Post: arunkhan
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,403 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 1,977 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 703 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 907 10-07-2022, 07:50 PM
Last Post: rookie_267
