RockPro64 & Roshambo Case
Hi everyone,
I have installed Lakka on my Rockpro64 and I have a Roshambo case, when I start the system, fan, on/off, reset and led don’t work, the OS starts normally but I have to plug/unplug the cord. Also don’t see the system reading the Roshambo cartridge, it only reads it if I use an adapter to the usb. Any idea how could I get the case working fine? also would be possible to use a generic Wi-Fi dongle as I don’t have the dedicated module?
do I need to add a script? I found this online
https://github.com/mrfixit2001/KintaroSnes-Rock64
Thanks in advance Smile
(10-13-2019, 01:16 PM)Gouki Wrote: Hi everyone,
Hi, yes if you want to make use of those extras (Power/Reset buttons, Power on LED and the fan), you need to add these scripts (but the fan can also be operated with some more fashion way (ATS: https://forum.pine64.org/showthread.php?tid=6953).
About the wifi dongle, I don't know since I use the cable Smile
Cheers!
(01-07-2020, 04:39 AM)Maxpako Wrote:
(10-13-2019, 01:16 PM)GoukiI Wrote: Hi everyone,
Cheers!
If you are using Lakka is impossible to install any script, there is no way we can add anything,all the folders are in read only and there is no way to make the fan and roshambo work
  Installing Wifi drive for the RockPro64 John45595 0 174 02-10-2024, 11:32 PM
Last Post: John45595
  Roshambo 2023 angeloweb 2 1,268 12-19-2023, 03:07 AM
Last Post: Maxpako
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 673 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 627 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,085 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 835 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,240 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,702 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,519 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 959 01-27-2023, 07:43 PM
Last Post: Spater
