Notebook-workstation for power users?
I am a bit too much of a pragmatist. I will order a Pinebook Pro in the future -- my current laptops have worse specs, being about a decade old. The issues I have are with software -- photo processing and statistical analysis -- and at present I'm haning off for a couple of months waiting for the first issues to be sorted and at that time I'll probably have a dead laptop that I need to replace.
Rant on: most CPUs we have can do almost anything you want to do at a reasonable speed. Bar gaming, and perhaps video processing. The issue is having a kernel that plays nicely with the software. If you think of it, a Chromebook assumes that the cheap processors we have can run anything via a web browser. Power users now are either running massively parallel systems, or gamers. Rant off.
(07-30-2019, 11:01 PM)weka Wrote: I am a bit too much of a pragmatist. I will order a Pinebook Pro in the future -- my current laptops have worse specs, being about a decade old. The issues I have are with software -- photo processing and statistical analysis -- and at present I'm haning off for a couple of months waiting for the first issues to be sorted and at that time I'll probably have a dead laptop that I need to replace.
"The issues I have are with software -- photo processing and statistical analysis"
If you have used Linux before and open source software, you won't even realise that you are not any longer on a X86 machine because they are identical on ARM and run natively. GIMP for photo processing and R Studio for statistical analysis are great open source applications you can run on Pinebook.
The problems start when you are trying to run proprietary software and drivers. If you stay away from them you are okay.
I haven't used windows or Apple OS for years now and I can do all my scientific work on Linux perfectly fine.
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 623 09-02-2023, 10:13 AM
Last Post: lupyuen
  Pine Desktop PowerSupply wont power on BSharp 5 1,636 08-29-2023, 08:06 AM
Last Post: chickenplusone
  power/battery usage on risc-v vs arm64? zetabeta 1 693 08-28-2023, 01:23 AM
Last Post: alphonso
  Link USB power strips for a cluster? DevonBirch 4 3,299 08-10-2023, 09:11 PM
Last Post: halibutdreary
  Plans for higher Power PinePowers PMARC14 0 499 07-14-2023, 03:03 PM
Last Post: PMARC14
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 1,077 04-17-2023, 05:00 AM
Last Post: lkoini
  Possible Uninterruptible power supply for Pine64's SBC's GreyLinux 10 4,958 02-11-2023, 03:15 AM
Last Post: ToryRutter
  PinePower USBench concept: Usb C universal/lab power supply (=48V5A PD 3.1 trigger) ijsbeer 3 2,851 04-16-2022, 04:59 PM
Last Post: ijsbeer
  Pinenut power consumpiton wytrzeszcz 0 846 03-22-2022, 01:31 PM
Last Post: wytrzeszcz
  PinePower desktop micro power breaks jpalus 4 4,529 08-08-2021, 04:57 PM
