Another non-booting ROCK64
Hey all,
I picked up a ROCK64 from ebay for a project I am working on.  But I have been unable to get it to boot.
The board was new, in a sealed static bag, with a 32gb SanDisk card and a 3amp wall wort.  The board is marked "V2"
I have tried numerous images and numerous SD cards including Samsung EVO cards, numerous writing methods, pine64 installer, etcher, dd, etc.
99% of the time I just get 3 solid LEDs on the board and no video output.  One image booted to a command prompt ONE time, the MrFixit image that was prepared for the v3 board, linked in this post:  Rock64 v3 and SD-Cards.  However, that singular boot has never been repeated.
a few of the images I have tried:
 Armbian_5.88_Rock64_Ubuntu_bionic_default_4.4.180_desktop
 rock64-debian-mrfixit-050919_2
 xenial-minimal-rock64-0.5.10-118-arm64
 bionic-lxde-rock64-0.7.9-1067-arm64
and most of the options available in the pine64 installer for a rock64 v2.
I checked the power supply, and it shows 5.2v without load.  I don't have access to hardware to try to hit the serial TTY.
I am fresh out of ideas here.  What is the likelihood that I am just unlucky and this board is bad?  Anybody have other ideas?
(06-07-2019, 12:20 PM)SuburbanDad Wrote: 99% of the time I just get 3 solid LEDs on the board and no video output.  One image booted to a command prompt ONE time, the MrFixit image that was prepared for the v3 board, linked in this post:  Rock64 v3 and SD-Cards.  However, that singular boot has never been repeated.
Are you using a tv or monitor?
Are the LAN LEDs lit?
if it gets a dhcp address is it pingable?
Have you tried booting without an SD card installed. If so what does your LED light sequence look like in comparison. Might be a faulty card reader on board.
1080p tv.  The ethernet port shows a link light, but it definitely never shows up on the network.  The one time I was able to get this thing to boot, it was not connected to a network.  Mostly, all the lights light up and stay lit, no flashing or anything that indicates it is doing anything at all.
(06-09-2019, 07:07 AM)Rocklobster Wrote: Have you tried booting without an SD card installed. If so what does your LED light sequence look like in comparison. Might be a faulty card reader on board.
Without an sd card, it does the same thing - nothing.  I don't have an eMMC module, and I'd like to see this board do something (anything) before I drop more $ on bits for it.
The Armbian image is the most stable in my experience. Definitely sounds like a faulty card reader. A dry solder joint possibly as you managed to boot to the CLI at one stage. The LEDs on the board stay powered on even when the board has booted.
One option would be to use a different card reader/writer to create your SD card image. Might be worth a try before you get in any deeper.
Like you say throwing more money at the problem is not desirable. What you could do is gently heat the board around the card reader area with a hair dryer or a heat gun to see if this might isolate the problem, obviously with the board powered down and the card out of the reader
(06-10-2019, 03:50 PM)Rocklobster Wrote: The Armbian image is the most stable in my experience. Definitely sounds like a faulty card reader. A dry solder joint possibly as you managed to boot to the CLI  at one stage. The LEDs on the board stay powered on even when the board has booted.
I re-tried armbian 5.75.  And although I still get no video (with a ~5' hdml cable to 1080p tv) it actually booted after about 10 minutes.  I did finally find it on the network and was able to login  Exclamation
`dmesg` output ends with these pertinent errors:
Quote:[  730.304133] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[  730.304164] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[  730.304177] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[  730.304189] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[  730.304200] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[  730.304212] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
does that ring a bell for anyone? a rock64 v2 running armbian 5.75
TIA
managed to get the Android 8.1 image to work with HDMI, so it is definitely a software issue.
Armbian 5.75 comes up without video, but with network and ssh
Armbian 5.88 no video, no network - but I noticed while changing the hdmi between it and an rpi, the rock64 briefly displayed tell tale init script output.
It is promising enough that I went ahead and snagged an eMMC module Smile
Thx for the armbian tip @Rocklobster  - I just needed to find an image that failed gracefully enough to still boot with networking and ssh.  Now just need to figure out what knobs to fiddle with to get hdmi working.
Just a tip. Avoid hot plugging the HDMI cable at the board end connector. I've seen many Raspberry Pis fried by doing this. Just to rule out a cable issue, try a different HDMI cable. They vary in quality. Post back your results
(06-15-2019, 04:14 AM)Rocklobster Wrote: Just a tip. Avoid hot plugging the HDMI cable  at the board end connector. I've seen many Raspberry Pis fried by doing this. Just to rule out a cable issue, try a different  HDMI cable. They vary in quality. Post back your results
I didn't have another cable on hand, but did have a spare cheapo tv to try, and it works like a champ.  Undecided   Well, the console displays, but the aspect ratio is very wrong, it looks like what I get when I do the RPI hot-swap. I am guessing the cheapo tv is a bit more forgiving. There are wide black bars on either side of the diplay and the top and bottom are chopped off, quite a lot - 18 lines on the console.
Thx for the help so far, any tips about hdmi setup greatly appreciated
Rebooting with the new tv connected, the aspect ratio is fixed.  I am guessing the auto-sensing hdmi on the other TV is causing uboot to get incorrect display info.
Thx
90% of HDMI issues are caused by badly manufactured or poorly screened cables. If you're using a desktop version Distro your system is left hanging as you've seen. Don't forget avoid plugging your HDMI cable when your board is powered up. Glad you got sorted!!!
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 1 118 03-18-2024, 06:56 AM
Last Post: diederik
  Rock64 bricked shawwwn 7 5,463 03-17-2024, 12:22 PM
Last Post: dmitrymyadzelets
  Rock64 won't boot luminosity7 10 3,872 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 258 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,774 04-29-2023, 04:24 AM
Last Post: newestssd
  OpenWRT on the Rock64 CanadianBacon 12 7,813 04-24-2023, 12:40 PM
Last Post: arunkhan
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,404 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 1,977 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 703 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 908 10-07-2022, 07:50 PM
Last Post: rookie_267
