Rock64 v3 - POE
Are there any specific requirements on the POE side for the Rock64 rev3?
(06-04-2019, 05:36 PM)P1V Wrote: Are there any specific requirements on the POE side for the Rock64 rev3?
PINE64 currently created a 802.11 AT PoE add-on board and will release in few weeks time. The schematic will be published when PoE add-on board released.
Bug
I began to implement PoE but I found problem. If I use PI2/PI5 connector to feed from internal PoE there is ferrite bead "L3203" between 5V (connector) and VCC_SYS (system) (see official schematics). L3203 is BLM18PG181SN1 but it is rate only to 1.5A DC current ! It fries itself with higher currents.
Did you use in final version BLM18PG181SN1 or BLM18PG330SN1 (3A version) or 0ohm resistor as in my Rock64ver3 sample ?
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
POE implementation was successful. POE PD 5V RT9400 ($4, 14mm width to attach in common case) + power button ML6-H1S12BVA ($1.5) + case EM-RasPI B+ basic ($6) + silicone thermal pads with adhesive to attach/cool POE (1mm/3mm) + cables and connectors + some passives = ~$13.
Implementation notes:
  • * Power button LED with 100 Ω resistor to 5V (20mA/3V LED forward voltage). Power button GND switch to PWRON connector (with internal pullup in RK805).
  • * Additional LOAD 120 Ω resistor between GND-5V (40mA) (or add more LEDs) to get minimum required power draw from POE PD with power off ROCK64 (very unlikely state). 60mA (20ma+40ma) generates power ripple about 0.2V and switching frequency about 2000Hz, officially RT9400 need at least 200mA (with low ripple). With Additional POE capacitor (see below) it works event without LOAD resistor.
  • * Additional POE 270 kΩ resistor between RT9400 ADJ and -VDC (GND) to adjust regulated voltage from ~5.0V to ~5.1V.
  • * Additional POE 470 µF/16V capacitor with low ESR between +VDC and -VDC (GND) (Hitano EXR and not from SYK).
  • * POE switch reports 2.1W/44mA when booted idle (CPU 400MHz, temperature 50C), 5.2W/110mA when stressed ("stress --cpu 4 --vm 2 --vm-bytes 128M", CPU 1296MHz, temperature up to 90C in assembled case) without any USB device connected (booted from SDcard) and 0.2W/6mA when power off ROCK64.
  • * Estimated 1A is available to USB devices.
  • * Test with HDMI connected, 2xUSB mouse+keyboard and USB3 HDD (Samsung EVO (rated 1200 mA) connected over AXAGON USB to SATA adapter 6G), POE switch reports maximum 8.9W/188mA.
    # lsusb -t
    /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
        |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
    /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
        |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M
        |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
    # lsusb -v 2>/dev/null | grep MaxPower | grep -v " 0mA"
        MaxPower              896mA
        MaxPower              100mA
        MaxPower              100mA
    # ### IDLE reported from switch - average 3.7W/77mA
    #  while true; do cat /sys/devices/virtual/thermal/thermal_zone0/temp /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq; iostat 1 2 | tail -2;  done
    58181
    408000
    sda               0.00         0.00         0.00          0          0
    # ### DD reported from switch - average 6.8W/144mA
    # dd if=/dev/sda of=/dev/null bs=1024k
    69230
    1296000
    sda            2435.00    311552.00         0.00     311552          0
    # ### DD+stress reported from switch - average 7.6W/159mA and max 8.9W/188mA
    # ### less stress to allow some CPU for USB3/DD processing
    # stress --cpu 1 --vm 1 --vm-bytes 128M
    88076
    1296000
    sda            1986.00    254208.00         0.00     254208          0
[Image: rock64-poe.jpg]
Actual versions of POE (~ $4 (poe) + $1 (capacitor+connectors)) without poweron button for RaspberyPI 4 (Rock64 v3 compatible).
[Image: cheap-poe-8023af-pd-for-sbc.jpg]
The last post. Farewell.
Away
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 286 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,331 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,692 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,154 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 337 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,894 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,533 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,109 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 761 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 957 10-07-2022, 07:50 PM
Last Post: rookie_267
