First Manjaro Mainline build!
Thumbs Up
The first build of Manjaro for the RockPro64 is now available for testing.
Learn more here
Hi all,
Wrote Manjaro to 16Gb SanDisk SD card, booted, console on serial port at 1500000 baud.
Setup my user, password, root password and Timezone, nothing on HDMI.
As root did: pacman --init
"pacman" times out getting files whereas "wget" succeeds??
added to /etc/hosts: 67.242.109.89 y0sh.co
pacman -S -y
pacman -S -u
Updated well until doing Firefox and crashed.
Next boot crashed at:
failed to execute /sbin/init: Exec format error
Now re-writing SD card.
Boots up fine to Serial console, it did blank the HDMI monitor temporarily.
Again, issues with the 1st login, setup user, password, root password etc. but got there.
Succeded with Package Update:
pacman -S -y
pacman -S -u
Mounts my USB3 cradle and Crucial 250Gb SSD.
SSH logins work fine but no X, as in ssh -Y user@host.
uname -a
Linux rockpro64 5.1.15-1-MANJARO-ARM #1 SMP Wed Jun 26 14:44:34 UTC 2019 aarch64 GNU/Linux
I'm now looking for tools to build software. Need "cmake" and a c++ compiler.
Added Manjaro KDE ARM (ROCKPRO64) preview 1 on Wiki and PINE64 Installer.
Updated Manjaro KDE ARM (ROCKPRO64) 19.06 on Wiki and PINE64 Installer.
Added Manjaro LXQT ARM (ROCKPRO64) 19.06 on Wiki and PINE64 Installer.
Added Manjaro Minimal ARM (ROCKPRO64) 19.06 on Wiki and PINE64 Installer.
Note : This 3 build not working for eMMC module, as unable get display via HDMI.
I noticed that the fan interface (/sys/class/hwmon/hwmon0) is not there. Haven't dug around yet to find a reason
(07-17-2019, 04:50 PM)mknawabi Wrote: I noticed that the fan interface (/sys/class/hwmon/hwmon0) is not there. Haven't dug around yet to find a reason
Manjaro is on mainline isnt it? probably didn't include the fan pwr control.
Yeah its mainline so only the submitted DTS in mainline.
Manjaro are doing such great work but tend to prefer to stick pure mainline so they can offer an array of SoCs without the huge specific support needs.
It would be really great if Pine could add a repo that has the small additional difference such as maybe fan & pcie, overlays and such as packages to help support the great work manjaro do.
Its great ref for the rockpro64 as simple dts omissions are highlighted pretty quick and there is a current 5.3 window
PS Mesa is lagging behind kernel obviously as they need the base kernel first, but Panfrost is coming on in leeps and bounds and with Linux 5.2.1 try compiling the mesa master 19.2.0-devel as its looking really good and as the devs say optimisation is still to come.
 https://gitlab.freedesktop.org/mesa/mesa
sudo pacman -S bc python-pip flex bison base-devel ncurses cmake xorg-util-macros
sudo pip install scikit-build mako
sudo pip install meson ninja
git clone https://gitlab.freedesktop.org/mesa/mesa.git -b master
cd mesa
mkdir build
meson -Ddri-drivers= -Dvulkan-drivers= -Dgallium-drivers=panfrost,kmsro -Dlibunwind=false -Dprefix=/usr build/
ninja -C build/
sudo ninja -C build/ install
19.2.0 is 2019-08-06 but looking like its complete or very near
https://www.mesa3d.org/release-calendar.html
Will rp64 also get the love that pinebook pro is getting?
Please look @
/sys/devices/platform/pwm-fan/hwmon/hwmon3/pwm1
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
i installed Manjaro-ARM-sway-rockpro64-20.10.img.xz
hdmi resolution is pretty wrong and edid seems to not work. is there a fix for this?
i tried forcing the mode in sway but it doesnt help.
how can i check if its using panfrost?
  [Manjaro] Fixing /etc/fstab from serial console while using lvm2 Dendrocalamus64 0 166 10-16-2025, 05:58 PM
Last Post: Dendrocalamus64
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,460 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,451 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 6,667 04-23-2023, 01:32 PM
Last Post: diederik
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,035 02-17-2022, 12:10 PM
Last Post: flounder
  CPU Fan Won’t Turn On in Manjaro publiclewdness 0 1,657 12-31-2021, 12:51 AM
Last Post: publiclewdness
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 3,827 09-11-2021, 08:58 PM
Last Post: t4_4t
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 2,543 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  Headphone jack issues Manjaro Mangled 2 4,300 03-06-2021, 11:01 PM
Last Post: Mangled
Question Mainline Debian Buster on RockPro64 ? chrestomanci 36 54,644 02-14-2021, 02:37 PM
Last Post: foresto
