Add separate power button?
Anyone try to add a separate power button and unhook the power button from the keyboard?  The current one being a regular keyboard key instead of a separate button has caused me some issues.
(12-17-2018, 02:33 PM)maddmike Wrote: Anyone try to add a separate power button and unhook the power button from the keyboard?  The current one being a regular keyboard key instead of a separate button has caused me some issues.
I've had and then not used a separate power cable /w button on my Rockpro64 and think these SBCs are sensitive to amp and voltage fluctuations caused by these ?higher resistance? cables.  I know I can not use them at all on my XU4s.
Ugh! Okay, this is getting to be a real PIMA.  Thanks for the comment.
  pinebook 1080p power/barrel connector/cable cel 0 496 08-03-2023, 11:43 AM
Last Post: cel
  Disable auto power on? cel 0 2,564 12-22-2019, 08:41 AM
Last Post: cel
  Power supply clarification maldus 5 5,983 12-17-2018, 03:55 AM
Last Post: maldus
  Power LED / Charging LED Question d97 4 5,124 11-21-2018, 10:26 AM
Last Post: Noxmiles
  UK Power Adapter? dejan 5 6,519 12-06-2017, 04:44 PM
Last Post: DigitalStefan
  Internal power connector problem stealthbanana 1 2,906 09-19-2017, 10:45 AM
Last Post: MarkHaysHarris777
  noise random green pixel when plugged power supply only (solved. see edit.) BatteryDie 5 6,495 09-06-2017, 04:17 PM
Last Post: BatteryDie
Question Power Related Problem Questions p3p1 1 2,497 08-29-2017, 06:06 PM
  Wanted: Better power adapter for Pinebook. flingtoad 4 6,236 08-21-2017, 10:09 PM
Last Post: Siliconserf
Thumbs Down Power Supply Design Flaw Siliconserf 11 11,923 08-15-2017, 12:26 PM
