No sound output from 3.5mm jack
Exclamation
Hey fellow Rockers,
I'm having some trouble getting sound to play from the 3.5mm port on my rockpro 64
Kernel: Linux rockpro64 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64 GNU/Linux
Distro: Debain Stretch 9.6
This is my first time encountering an audio problem so I'm not 100% I went through the all basics, but here's what I've done so far:
  • Verified my user is in the audio group
  • installed pulseaudio and pavucontrol
  • changed my default sinks to every option available with pacmd change-default-sink
  • verified my volume was turned up in alsamixer
  • played a known good file with aplay as local user and su
  • tried a new headset, and tried the same headset in a different device. The headset is good.
  • Searched this forum and followed Longsleep's recommendations posted here
  • rebooted multiple times after iterating through these steps
None of these steps remedied the issue, and I still don't have any sound output from the 3.5mm. I was able to get audio through the HDMI port one time, but that happened unintentionally.
Sinks:
3 sink(s) available.
 * index: 0
    driver: <module-alsa-card.c>
    flags: HARDWARE DECIBEL_VOLUME LATENCY FLAT_VOLUME
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9009
    volume: front-left: 57659 /  88% / -3.34 dB,   front-right: 57659 /  88% / -3.34 dB
            balance 0.00
    base volume: 65536 / 100% / 0.00 dB
    volume steps: 65537
    muted: no
    current latency: 0.00 ms
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 0
    sample spec: s16le 2ch 44100Hz
    channel map: front-left,front-right
                 Stereo
    used by: 0
    linked by: 0
    fixed latency: 99.95 ms
    card: 0 <alsa_card.platform-es8316-sound>
    module: 6
    properties:
        alsa.resolution_bits = "16"
        device.api = "alsa"
        device.class = "sound"
        alsa.class = "generic"
        alsa.subclass = "generic-mix"
        alsa.name = ""
        alsa.id = "ff890000.i2s-ES8316 HiFi ES8316 HiFi-0"
        alsa.subdevice = "0"
        alsa.subdevice_name = "subdevice #0"
        alsa.device = "0"
        alsa.card = "0"
        alsa.card_name = "rockchip,es8316-codec"
        alsa.long_card_name = "rockchip,es8316-codec"
        device.bus_path = "platform-es8316-sound"
        sysfs.path = "/devices/platform/es8316-sound/sound/card0"
        device.string = "hw:0"
        device.buffering.buffer_size = "17632"
        device.buffering.fragment_size = "4408"
        device.access_mode = "mmap"
        device.profile.name = "analog-stereo"
        device.profile.description = "Analog Stereo"
        device.description = "rockchip,es8316-codec Analog Stereo"
        module-udev-detect.discovered = "1"
        device.icon_name = "audio-card"
   index: 1
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9009
    volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
            balance 0.00
    volume steps: 65537
    muted: no
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 2
                 Stereo
    used by: 0
    linked by: 0
    card: 1 <alsa_card.platform-hdmi-dp-sound>
    module: 7
    properties:
        device.api = "alsa"
        alsa.name = ""
        alsa.id = "HDMI-DP multicodec-0"
        alsa.device = "0"
        alsa.card = "2"
        alsa.card_name = "rk-hdmi-dp-sound"
        alsa.long_card_name = "rk-hdmi-dp-sound"
        device.bus_path = "platform-hdmi-dp-sound"
        sysfs.path = "/devices/platform/hdmi-dp-sound/sound/card2"
        device.string = "hw:2"
        device.description = "rk-hdmi-dp-sound Analog Stereo"
    ports:
        analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
            properties:
    active port: <analog-output>
   index: 2
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9009
            balance 0.00
    volume steps: 65537
    muted: no
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 3
                 Stereo
    used by: 0
    linked by: 0
    card: 2 <alsa_card.platform-spdif-sound>
    module: 8
    properties:
        device.api = "alsa"
        alsa.name = ""
        alsa.id = "ff870000.spdif-dit-hifi dit-hifi-0"
        alsa.device = "0"
        alsa.card = "1"
        alsa.card_name = "ROCKCHIP,SPDIF"
        alsa.long_card_name = "ROCKCHIP,SPDIF"
        device.bus_path = "platform-spdif-sound"
        sysfs.path = "/devices/platform/spdif-sound/sound/card1"
        device.string = "hw:1"
        device.description = "ROCKCHIP,SPDIF Analog Stereo"
    ports:
            properties:
I'm not sure what to do next, so here I am. Thanks in advance for any assistance.
PS. lspci produces no output. Is this normal?
(12-10-2018, 06:05 AM)spatial_dreams Wrote: I'm having some trouble getting sound to play from the 3.5mm port on my rockpro 64
I have yet to get any sound out of my 3.5mm port under Linux. There are various "hints" that it is possible - I am sure it is but nobody has yet given instructions that made sense to me. e.g. see this thread. The one thing that I haven't tried, that IMHO may be worth a shot, is Armbian.
(12-10-2018, 06:05 AM)spatial_dreams Wrote: PS. lspci produces no output. Is this normal?
Yup - the pci (linux) modules are compiled as option to load ("M" only if needed).
(12-10-2018, 06:05 AM)spatial_dreams Wrote: Hey fellow Rockers,
None of these steps remedied the issue, and I still don't have any sound output. It's possible that it's sending the signal through the HDMI cable, but my monitor doesn't support audio so I can't tell.
Sinks:
 * index: 0
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9009
            balance 0.00
    volume steps: 65537
    muted: no
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 0
                 Stereo
    used by: 0
    linked by: 0
    module: 6
    properties:
        device.api = "alsa"
        alsa.name = ""
        alsa.device = "0"
        alsa.card = "0"
   index: 1
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9009
            balance 0.00
    volume steps: 65537
    muted: no
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 2
                 Stereo
    used by: 0
    linked by: 0
    module: 7
    properties:
        device.api = "alsa"
        alsa.name = ""
        alsa.device = "0"
        alsa.card = "2"
    ports:
            properties:
   index: 2
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9009
            balance 0.00
    volume steps: 65537
    muted: no
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 3
                 Stereo
    used by: 0
    linked by: 0
    module: 8
    properties:
        device.api = "alsa"
        alsa.name = ""
        alsa.device = "0"
        alsa.card = "1"
    ports:
            properties:
We, collectively, can't get sound working from the 3.5mm port in Linux?
  Tested PCIe cards and output kram0000 5 6,144 10-24-2019, 01:17 PM
Last Post: xalius
  No boot with Supermicro AOC-SASLP-MV8 (serial output) kram0000 0 1,775 10-22-2019, 04:00 PM
Last Post: kram0000
  rockpro64 buzzing sound when running dbittman 1 2,516 09-05-2019, 10:57 AM
Last Post: Nikolay_Po
  Rock 64 Pro sound issue MH12 5 6,311 01-08-2019, 05:58 PM
Last Post: Don
