[SOLVED] Can't boot when SD card inserted
I used a 64GB microSD card to install Q4OS to the EMMC card.
I was able to boot to Q4OS from the SD card when the original KDE Neon was on the EMMC.
Now, I normally boot from EMMC to Q4OS.
So, I re-formatted the microSD card, in order to use it for extra storage.
It works OK, I can mount the card and read/write files on it.
BUT -
If I reboot with the card inserted, my Pinebook will not boot. Black screen, no error message.
I have to remove the card and hard-reboot, then re-insert the card.
There is something on the card that makes the Pinebook try to boot from it, but there's no boot partition on the card:
adminq@pinebook1080p:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        15G  5.7G  8.1G  42% /
devtmpfs        798M     0  798M   0% /dev
tmpfs           995M   17M  979M   2% /dev/shm
tmpfs           995M  8.7M  987M   1% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           995M     0  995M   0% /sys/fs/cgroup
/dev/mmcblk0p1  100M   23M   77M  23% /boot
tmpfs           199M   12K  199M   1% /run/user/1000
adminq@pinebook1080p:~$ lsblk
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk0      179:0    0 14.6G  0 disk
├─mmcblk0p1  179:1    0  100M  0 part /boot
└─mmcblk0p2  179:2    0 14.5G  0 part /
mmcblk0boot0 179:8    0    4M  1 disk
mmcblk0boot1 179:16   0    4M  1 disk
mmcblk1      179:24   0   60G  0 disk
└─mmcblk1p1  179:25   0   60G  0 part
If I insert a different microSD card, from my Android tablet, there is no such problem.
What do I have to remove or add to the 64GB card so that Pinebook doesn't try to boot from it?
Further to this problem.
I used the Pinebook Installer to write ARCH Linux image onto the 64GB card.
It still won't boot, and now it won't mount, either.
Does this dmesg|tail output suggest what is wrong with the card?
adminq@pinebook1080p:~$ dmesg|tail
[  195.062891] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[  195.098407] mmc2: host does not support reading read-only switch. assuming write-enable.
[  195.107276] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 25000000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[  195.119012] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 25000000Hz bm PP pm ON vdd 16 width 4 timing LEGACY(SDR12) dt B
[  195.130659] mmc2: new SDXC card at address 0001
[  195.137285] mmcblk1: mmc2:0001 SD16G 60.0 GiB
[  195.145172]  mmcblk1: p1 p2 p3
[  227.609344] systemd[1]: local-fs.target: Cannot add dependency job, ignoring: Unit -.mount is masked.
[  274.112550] JBD2: Unrecognised features on journal
[  274.125997] EXT4-fs (mmcblk1p3): error loading journal
Perhaps you have already tried this, but if you remove the SD card, will it boot off of the eMMC?
It appears that the Pinebook has a boot order, of SD slot, then eMMC. Not sure if this can be changed (or if it is a good idea to change it)
Thank you for the reply. @cvmiller.
Yes, it boots from EMMC as long as that "poison" 64GB microSD card is not inserted.
And it boots when a different microSD card is inserted.
The problem is with that particular card, Pinebook "thinks" it should boot from it, but there's nothing there.
(11-17-2018, 07:18 AM)jschall Wrote: The problem is with that particular card, Pinebook "thinks" it should boot from it, but there's nothing there.
Even if you re-formatted the partition, this doesn't remove the u-boot sectors from SDCard ...
To get rid of u-boot, you need to erase few sectors with the following command :
dd if=/dev/zero of=/dev/mmcblk0 bs=1024 seek=8 count=2048
Merci, @martinayotte, for your reply.
But I think that should be /dev/mmcblk1, because /dev/mmcblk0 is my EMMC!
@martinayotte, your dd suggestion worked!
Thank you.
Now I have a 64GB microSD card that I can leave inserted while rebooting from EMMC.
Thank you.
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 1,777 12-07-2020, 04:02 PM
Last Post: SanjevR
Lightbulb Boot from SD card / boot options lodger 13 10,895 11-26-2019, 07:14 AM
  eMMC boot linux distros for Pinebook. frank-zappa 14 6,897 09-06-2019, 08:39 AM
Last Post: frank-zappa
  Link to 11.6 pinebook mainboard schematics for removing wifi card Shoananas 0 662 05-19-2019, 04:46 PM
Last Post: Shoananas
  Is it possible to choose between SD/eMMC boot programmatically? UltraBloxX 2 1,638 01-28-2019, 11:41 AM
Last Post: UltraBloxX
  Boot from MicroSD ramboton 3 1,647 11-16-2018, 06:04 PM
Last Post: Luke
  [SOLVED] HELP! Four clocks on panel! jschall 2 1,076 11-16-2018, 09:55 AM
Last Post: jschall
  How to mount new microSD card? jschall 8 3,201 11-12-2018, 11:04 AM
Last Post: jschall
  Move Installation from SD Card to eMMC? soupbowl 4 3,405 11-10-2018, 10:47 AM
Last Post: acruhl
  Dual Boot on eMMC? d97 1 1,863 08-30-2017, 10:04 AM
Last Post: abrmx
